Aluminium RaspDAC BOX for I-Sabre ES9038Q2M & Raspberry Pi 3 B+
This case has been designed by Audiophonics specifically to accommodate and protect the Raspberry Pi and DAC ES9038Q2M
Reference : 12546
54,90 €tax incl.
45,75 € tax excl.
Audiophonics ES9038Q2M Casing / Raspberry Pi
boitier pour raspdac ES9028Q2M
This 100% Aluminium case designed by Audiophonics can accommodate the Raspberry Pi 3 B+ and DAC I-Sabre ES9038Q2M, in order to mount a RaspDAC.
As a result, and in order to take advantage of all the system's functionalities, this box has all the necessary notches and markings, in order to access the connection. There are also slots for adding an ON/OFF knob, a rotary knob for volume/source control and two screens (sold separately).
The sturdy and stylish case will protect your components from shock and dust and integrate seamlessly into your audio system.
Warning: Only the case, screws and upper button are delivered. Raspberry Pi and DAC ES9038Q2M can be purchased separately. Warning: soldering is required to connect the Winstar display and the AUDIOPHONICS Pi SPC II module. This box is not a complete kit and comes bare without assembly instructions.
The connection of the main Winstar display and SPC II is available: on this PDF.
All other connection information for the DAC (small 1-inch 11573 display) is on the DAC data sheet:
Es9038Q2M
This product is only compatible with the Raspberry Pi 3. It is not compatible with Raspberry Pi 4.
Matérial100% Aluminium anodized
White SerigraphyYes
Dimensions160 x 140 x 50mm
Drilling dimensions front panel65 x 16mm
Entraxes afficheur face avant75 x 31mm
Distance between centres front panel display32 x 17mm
Top display centre distances30 x 28mm
Weight620g
Hole for infrared receiverYes
Hole for Micro SD portx1
Hole for RJ45 port1x
Hole for USB-A port2 holes for 4 USB-A ports
Hole for HDMI port1x (holes distances : 30mm)
Analog output RCA Stereo1x (⌀12mm)
Hole for DC Jack1x (⌀8mm)
Drilling for front panel switch1x (⌀19mm)
PackageBox
Bodywork
Button upper
MaterialAluminium
Internal width160
Internal depth140
Internal height50
Download
câblage_es9038_power_mgmt
Wiring GPIO map for power management module & Winstar
Download (1.43M)
