DAYTON AUDIO KABD-250 Bluetooth 5.0 Stereo Amplifier Module Stéréo
The Dayton Audio KABD-250 module is an amplifier module capable of delivering up to 2x 50W into 4Ω thanks to a TPA3116 chip. In addition, this module incorporates a DSP chip to give you complete control over the final sound. Finally, for maximum convenience, this module also includes a Bluetooth 5.0 chip that supports aptX HD, aptX LL, SBC and AAC codecs.
Reference : 21222
89,91 €tax incl.
74,92 € tax excl.
Grantie 5 ans
Dayton Audio KABD-250 Bluetooth 5.0 Stereo Amplifier Module Stéréo TPA3116 2x50W 4 Ohm
Dayton Audio KABD-250 : Front view
Dayton Audio KABD-250 : 2x50W amplification
The Dayton Audio KABD-250 card incorporates a Class D amplifier module based on the TPA3116 chip. With an efficiency of nearly 88%, this chip delivers 2 × 50 W of power into 4 Ω while significantly limiting heat generation, allowing for the use of a smaller heat sink. Its ultra-low distortion and low power consumption make this board particularly suitable for portable battery-powered installations.
Dayton Audio KABD-250 : TPA3116 chip
Dayton Audio KABD-250 : ADAU1701 DSP
The card also features an ADAU1701 digital signal processor, paving the way for signal processing via SigmaStudio software. This DSP makes it possible to adjust equalisation, high-pass and low-pass filters, tone, time alignment and many other functions. External potentiometers can be connected to the card to adjust volume and settings in real time.
Dayton Audio KABD-250 : Bluetooth 5.0
For the wireless part, the KABD-250 card incorporates a Bluetooth 5.0 module with aptX HD, aptX LL, SBC and AAC support, ensuring near CD-quality streaming and low latency. The module has high sensitivity, RF power up to +9 dBm, and an external antenna connector to optimise range (up to approximately 15 metres).
Dayton Audio KABD-250 : Bluetooth 5.0 chip
Product typeAmplifier module
Channel number2
Amplification chipTPA3116
DSPADAU1701
Output power2x50W @4Ω
2x30W @8Ω
Input impedance2x50W @4Ω
2x30W @8Ω
Signal-to-noise ratio (SNR)91dB
Total harmonic distortion more noise (THD+N)0.039% @10W 4Ω, 1kHz
Output noise level163μV
Crosstalk-60dB
aptX LL
SBC
AAC
Power supply voltage12-26V
Dimensions91.4 x 68.6 x 22.9mm
Weight160g
Package1x Dayton Audio KABD-250
1x 50 cm power cable
1x 50 cm speaker cable
1x Bluetooth reset button with 50 cm cable
InputMolex
OutputPCB Connector
Channel2 (Stereo)
Amplifier chipTPA3116
Power (W)50.0
DAYTON AUDIO KABD-250 Bluetooth 5.0 Stereo Amplifier Module Stéréo TPA3116 2x50W 4 Ohm
The Dayton Audio KABD-250 module is an amplifier module capable of delivering up to 2x 50W into 4Ω thanks to a TPA3116 chip. In addition,...
