TINYSINE TSA2210 Amplifier Kit
The TINYSINE TSA2210 is a ready-to-integrate stereo Bluetooth audio amplifier kit designed for both manufacturers and DIY enthusiasts looking to build their own active speaker or compact audio system.
Reference : 22045
29,57 €tax incl.
24,64 € tax excl.
Shipping date: 24-11-2026.
Tinysine TSA2210 TPA3110D2 Bluetooth 4.0 Amplifier Kit 2x 8W 4 Ohm
TINYSINE TSA2210
The Tinysine TSA2210 is a ready-to-integrate stereo Bluetooth audio amplifier kit designed for both manufacturers and DIY enthusiasts looking to build their own active speaker or compact audio system. It is based on a Class D architecture using the Texas Instruments TPA3110D2 chip and directly integrates a Bluetooth 4.0 receiver, enabling wireless audio streaming from a smartphone, tablet, or computer. The module delivers 2x8W of output power and can drive 4Ω or 8Ω passive speakers. The kit includes the TSA2210 amplifier board, a physical volume control knob, a waterproof green front-panel LED, and a connection cable. Operating from a 10.3V to 16V DC power supply (12V recommended), it can be powered either by an AC adapter or directly from a 12V battery.
The TSA2210 kit comes with all the components required for quick integration:
  • 1x TSA2210 Bluetooth amplifier board
  • 1x multifunction volume control knob
  • 1x waterproof green front-panel mounting LED
  • 1x connection cable
This turnkey solution provides an excellent foundation for compact DIY Bluetooth speakers, embedded audio systems, or any project requiring simple and efficient stereo amplification.
TINYSINE TSA2210
TINYSINE TSA2210: Integrated Bluetooth 4.0 Receiver
The module directly integrates Bluetooth 4.0 connectivity, allowing wireless music streaming from most compatible mobile devices and computers.
Once powered on, the module appears under the name "BT Speaker" when searching for Bluetooth devices. Pairing is performed without a PIN code, greatly simplifying setup. The Bluetooth device name can also be customized using a compatible programmer.
TINYSINE TSA2210: Multifunction Physical Volume Control
Unlike many compact Bluetooth modules, the TSA2210 features hardware-based volume control thanks to the potentiometer included in the kit.
Turning the knob directly adjusts the volume level, while pressing it turns the amplifier on or off. Volume can also be controlled from the connected Bluetooth device, providing great flexibility in use.
TINYSINE TSA2210 Overview
1Amplified output via screw terminal
212V DC power supply screw terminal
3PCB connector for potentiometer
4LED indicator screw terminal
5Bluetooth
Technical Specifications
Product typeAmplifier kit
Amplifier chipTPA3110D2
OutputScrew terminal
Output power2x8W @ 4 ohms
Input impedance30Kohms
Input sensitivity0.283V
Gain26dB
Recommended impedance4-8 ohms
Frequency response20Hz-22kHz
Power supply12V DC (10.3V-16V DC)
Standby current0.12mA @ 12V DC
DimensionsPCB: 4.8 x 8cm
Package contents1x TSA2210 Bluetooth amplifier board
1x Multifunction volume control knob
1x Waterproof green front-panel mounting LED
1x Connection cable
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)8.0
TINYSINE TSA2210 Amplifier Kit TPA3110D2 Bluetooth 4.0 2x8W 4 Ohm
The TINYSINE TSA2210 is a ready-to-integrate stereo Bluetooth audio amplifier kit designed for both manufacturers and DIY enthusiasts looking to...
