WONDOM AA-AB32174 Class D Amplifier Module TDA7492
The WONDOM AA-AB32174 is a Class D stereo amplifier module based on the STMicroelectronics TDA7492 chip, designed for DIY audio projects, active speakers, and multimedia systems requiring efficient, high-performance amplification. Powered by a DC supply ranging from 10V to 27V, it delivers up to 2x39W into 6Ω at 1% THD+N and can reach 2x50W into 6Ω at 10% THD+N with a 24V power supply.
Reference : 22264
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 24-11-2026.
WONDOM AA-AB32174 Class D Amplifier Module TDA7492 2x39W 6 Ohm
WONDOM AA-AB32174
The WONDOM AA-AB32174 is a Class D stereo amplifier module based on the STMicroelectronics TDA7492 chip, designed for DIY audio projects, active speakers, and multimedia systems requiring efficient, high-performance amplification. Powered by a DC supply ranging from 10V to 27V, it delivers up to 2x39W into 6Ω at 1% THD+N and can reach 2x50W into 6Ω at 10% THD+N with a 24V power supply. Its Class D architecture provides high efficiency ranging from 88% to 93%, reducing power consumption and heat generation. The module features a power indicator, adjustable gain, as well as overcurrent and overtemperature protection circuits to ensure reliable operation. It also benefits from an optimized thermal design with an integrated heatsink and supports an optional thermally controlled cooling fan. Compatible with speaker loads from 4Ω, it measures 122 x 91 x 39mm and weighs approximately 396g, making it easy to integrate into a wide range of audio projects requiring medium-power stereo amplification.
WONDOM AA-AB32174
WONDOM AA-AB32174 Overview
1Stereo RCA Analog Input
2Stereo Analog Input via Solder Pads
3MUTE/STBY (Solder Pad)
4Gain Adjustment (K1/K2)
510-27V Power Supply (Solder Pads)
6Stereo Speaker Output
710-27V Power Supply (DC Jack or Screw Terminal)
Technical Specifications
Product TypeAmplifier Module
ClassClass D
Amplifier ChipTDA7492
Inputs1x Stereo Input via RCA
1x Stereo Input via Solder Pads
Outputs1x Stereo Speaker Output via Screw Terminal
GainK1 ON, K2 ON: 21.6dB
K1 OFF, K2 ON: 27.6dB
K1 ON, K2 OFF: 31.1dB
K1 OFF, K2 OFF: 33.6dB
Input Sensitivity1658mV @6Ω, 50W, 1KHz
Input Impedance22Kohms
Output Power2x 39W @6Ω THD+N 1%
2x 50W @6Ω THD+N 10%
Bandwidth20Hz-20kHz @6Ω, ±3dB
THD0.041% @6Ω, 1W, 1KHz
0.051% @8Ω, 10W, 1KHz
Noise Level184.49µV
SNR95.775dB @39W 6Ω THD+N 1%
Minimum Load Impedance4Ω
Power Supply10-27V DC (24V typ.)
Idle Power ConsumptionFAN ON: 2.6-5W
FAN OFF: 1.7-3W
Standby Power ConsumptionFAN OFF: 0.7-1.5W
Max. Current4.63A @ 100W 6Ohm
Efficiency88-93% @ 50W @ 6Ohm
Switching Frequency350kHz
Dimensions121.92 x 91.44 x 38.86mm
Weight396g / 0.87 lbs (±10%)
Package Contents1x WONDOM AA-AB32174
InputSolder pad
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTDA7492
WONDOM AA-AB32174 Class D Amplifier Module TDA7492 2x39W 6Ohm
The WONDOM AA-AB32174 is a Class D stereo amplifier module based on the STMicroelectronics TDA7492 chip, designed for DIY audio projects, active...
