WONDOM BVS2300 Bluetooth 5.0 Stereo Amplifier Module TPA3255 2x300W 4 Ohm
The Wondom AA-AB32504 BVS2300 is an amplifier module capable of delivering up to 2x 300W @ 4 ohm thanks to a TPA3255 chip.
Reference : 20925
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 24-11-2026.
Wondom BVS2300 Bluetooth 5.0 Stereo Amplifier Module TPA3255 2x300W 4 Ohm
Photo du WONDOM BVS2300
The Wondom AA-AB32504 BVS2300 is an amplifier module capable of delivering up to 2x 300W into 4 ohm thanks to a TPA3255 chip. The module features a bypass mode, external potentiometer port, I2S output and BP1048 DSP. Bluetooth 5.0 functionality enables it to support SBC and AAC codecs for a reliable, stable connection. The module also works with ACP Workbench to fine-tune and customize sound rendering.
WONDOM BVS2300 module overview
Aperçu du module WONDOM BVS2300
1I2S output
2Volume control
3Line input (Bypass)
4Input selection switch
5Line input (with jumper)
6Line output
7Antenne Bluetooth
8Speaker output
9DC 18-48V power supply
10Speaker output
11PC UI programming
Product typeAmplifier module
Channel number2
Amplification chipTPA3255
DSP1048
InputsBluetooth
Line input (bypass)
Line input (jumper)
Outputs2x 2-pin mini-fit amplified output
Line output
I2S output
Supported Bluetooth codecsSBC AAC
 Audio Performances
ParameterConditionsTyp.
SNRLine Input bypass Bluetooth module 2 x 300W @ 4Ω, A-weightingOUT 1
OUT 2
96.2dB
95.9dB
Line Input through Bluetooth module 2 x 300W @ 4Ω, A-weightingOUT 1
OUT 2
95.2dB
95.0dB
THD+NLine Input bypass Bluetooth module 5W @ 4Ω, 1kHzOUT 1
OUT 2
0.0083%dB
0.0094%dB
Line Input through Bluetooth module 5W @ 4Ω, 1kHzOUT 1
OUT 2
0.0098dB
0.0125dB
Noise floorLine Input bypass Bluetooth module A-weighting, Input connected to GNDOUT 1
OUT 2
210.5uV
225.9uV
Line Input through Bluetooth module A-weighting, Input connected to GNDOUT 1
OUT 2
234.5uV
238.4uV
Input impedanceLine In & BT Line In @ 4Ω, 1kHz-20kOhm
SensitivityLine Input bypass Bluetooth module 2 x 300W @ 4Ω, 1kHzOUT 1 & OUT 24V
Line Input through Bluetooth module 2 x 300W @ 4Ω, 1kHzOUT 1 & OUT 24V
DC Bias-OUT 1 & OUT 215mV
Power supplyDC 18-48V (power supply sold separately)
Package1x WONDOM BVS2300 module
1x Power cable
2x 2-pin mini-fit cable
1x Potentiometer
1x 3.5mm jack line-in cable
InputPCB Connector
OutputPCB Connector
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)300.0
