By buying this product you get 51 loyalty points
With the exception of the ebenestry, this kit contains all the elements necessary for the manufacture of the ATOHM RAFALE V38S, an active subwoofer capable of restoring all the shades of the extreme low register with force and velocity.
Thanks to its numerous connection possibilities, the RAFALE V38S can easily be integrated into any type of installation Hifi and Home Cinema.
Hiswide laminar vent Strong>allows drastically reducing airflow noises below the bass-reflex tuning frequency.
Hergenerous power associated with a Exception loudspeaker will know to blow you by a precise grave, fast and deep to wish!
You will find in the documents enclosed below the complete technical data sheet. Strong>
Specifications: Strong>
For each model kit, Atohm offers a set of studied accessories including:
Various components :
TheLD230CR04is a boomer of23cmdesigned to restore the 30Hz - 200Hzwith a high level and low distortion rates. Thanks to the wide spider of specific regression geometry (the height of the turns not constant) and the peripheral suspension to the profile LDSTM(Low Diffraction Surrounding), this unit works under optimum conditions on a range of high - linear excursions out of the ordinary Strong>(+/- 10mm).
The imposing motorization(diameter 156mm) benefiting from the FWITM technology(Force Without Inductance) gives this unit an important force factor corroborated by a QTS ideal Strong>.
To drastically reduce operating noise at high amplitudes and to allow better cooling, the bowl (injected aluminum) Strong>and the cone have large ventilation holes.
Specializing in the design and manufacture of high-end loudspeakers and loudspeakers, ATOHM also designs amplifiers with a very high level of performancees.
Output stage ICE POWER Strong>TM with a power of 220Wrms under 4 ohms. Thanks to its class D technology, its excellent efficiency (80%) and its high damping factor make it compatible with any load impedance greater than or equal to 3 Ohm. Great musicality and generous power under a very small footprint!
