WBT-0661Ag Silver Forks Ø7mm (The pair)
Reference : 2239
117,50 €tax incl.
97,92 € tax excl.
In 1985, WBT designed the first machined connector in one piece with a progressive clamping device.
Since then, the machining technique has been refined, the eight outer contact lamellae are machined on high precision machines using diamond bits.
This patented design has the value of a symbol on the market.
WBT is today synonymous with perfection in the field of audio connection and its reputation is more to do.
In 2003, NextGen technology was introduced by pushing the conduction quality of WBT connectors even further.
Today, this principle extends to the entire range.
The terminal is connected to the cable by crimping.
The two leather-stamped camps on each lug are equipped with Torx screws, which provides a reliable high strength connection.
These forks are therefore fully insulated in accordance with EN 60065 and IEC65 standards.
It is designed for the use of crimped contacts using two Torx screws and accepts cables up to 10 mm² of cross-section.
Finally it is available in two sizes; 6 mm (WBT-0661) or 8 mm (WBT-0681) and in two metals: Pure copper covered with a protective layer in 24 karat Gold or Platinum thin silver plated.
Features:/ Strong>
  • Conducteur of signal cut in the mass of fine Silver
  • Acceptable Cable Diameter: 7mm
  • Width of the fork 6mm
  • Overall Length: 48mm
  • Diameter of the body: 16mm
  • Platinum Platinum
The WBT patent uses an absorbent elastomeric material sandwiched within the fork.
It makes it possible to establish an extremely high contact pressure during clamping, accepting a current of 100 A continuously.
Moreover, it absorbs vibrations and thus suppresses the generation of magnetostrictive noises.
Finally, it guarantees perfect mechanical strength over time.
Precision screwdriver available in the accessories below./ P>
[Img-13371-left-thickbox_default]
[Img-13372-left-thickbox_default]
Max cable diameter (mm)7.0
Mounting typeTo screw
ConnecticMale
