The Viablue T8 Screw RCA connectors combine flawless build quality with 24-karat gold-plated contacts, ensuring excellent signal conductivity while maintaining outstanding oxidation resistance for extended durability. The connector body is crafted from matte black aluminum, delivering both aesthetic refinement and structural integrity. M4 1.5mm hexagonal socket screws provide secure cable and connector retention within the body. The T8 SCREW accommodates cables ranging from 6mm to 8mm in diameter.
Technical Specifications
| Specifications | |
| Product Type | RCA Connectors |
| Contact Plating | 24k Gold |
| Body Material | Aluminum |
| Cable Diameter Min/Max | Min: 6mm Max: 8mm |
| Total Length | 45mm |
| Body Length | 30.5mm |
| Body Diameter | 13.5mm |
| General | |
| Color | Matte Black |
| Packaging | Sold as a pair (1 connector with red band, 1 connector with black band) |
| Max cable diameter (mm) | 8.0 |
| Mounting type | To screw |
| Connectic | Male |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
