FIIO SNOWSKY WIND Dynamic Headphones
The FiiO SNOWSKY WIND is a wired semi-open on-ear dynamic headphone, designed in a retro format inspired by the headphones of portable music players from the 1980s and 1990s.
Reference : 22434
19,00 €tax incl.
15,83 € tax excl.
FiiO Snowsky Wind Dynamic Headphones 40mm 32 Ohms 101dB 20Hz-20kHz Black
FIIO SNOWSKY WIND
The FiiO Snowsky Wind is a wired semi-open on-ear dynamic headphone, designed in a retro format inspired by the headphones of portable music players from the 1980s and 1990s. Particularly lightweight at approximately 50g, it combines a retractable stainless steel headband with swiveling earcups to facilitate adjustment and extended use.
The 40mm dynamic drivers use composite PET diaphragms imported from Japan and are integrated into a specially designed housing, providing a claimed frequency response of 20Hz to 20kHz, with a sensitivity of 101dB and an impedance of 32Ω. Its semi-open design promotes natural and transparent reproduction while retaining some awareness of the surrounding environment.
The WIND is supplied with two pairs of foam earpads, with the black earpads emphasizing bass more strongly, while the orange models offer a more balanced and relaxed sound reproduction. Its non-detachable braided cable terminates in a 3.5mm jack connector and integrates a microphone as well as a three-button control allowing calls and media playback to be managed.
FIIO SNOWSKY WIND
Technical Specifications
Product TypeHeadphones
Headphone TypeSemi-open on-ear
DriverDynamic Ø40mm
Diaphragm MaterialJapanese PET composite
MagnetN52
Voice CoilJapanese CCAW (copper-coated aluminum wire)
Impedance32 Ohms
Sensitivity101dB/mW (@1kHz); 116dB/Vrms (@1kHz)
CTIA Microphone
Media Control Buttons
Termination3.5mm Jack
Package Contents1x FiiO Snowsky Wind
2x Black foam earpads
2x Orange foam earpads
Impedance (Ω)32
Efficiency / Sensitivity (dB)101.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorNon-detachable cable
FIIO SNOWSKY WIND Dynamic Headphones 40mm 32 Ohm 101dB 20Hz–20kHz Black
The FiiO SNOWSKY WIND is a wired semi-open on-ear dynamic headphone, designed in a retro format inspired by the headphones of portable music...
