KIWI EARS ALTRUVA Headphones
The Kiwi Ears Altruva is an open-back circumaural headphone based on a 50 mm dynamic driver, whose PU + PEK composite diaphragm, combined with a pure copper surround, aims to achieve a balanced compromise between mechanical strength and response consistency. This design provides stable reproduction across the entire spectrum, suitable for versatile listening without artificial emphasis.
Reference : 21457
79,90 €tax incl.
66,58 € tax excl.
Shipping date: 17-11-2026.
Kiwi Ears Altruva Open-Back Dynamic Headphones 32 Ohm 98dB 20Hz-20kHz
Kiwi Ears Altruva : Front view
The Kiwi Ears Altruva is an open-back circumaural headphone based on a 50mm dynamic driver, whose PU + PEK composite diaphragm, combined with a pure copper surround, aims to achieve a balanced compromise between mechanical strength and response consistency. This design provides stable reproduction across the entire spectrum, suitable for versatile listening without artificial emphasis.
Its open architecture promotes more natural airflow, limiting internal reflections and contributing to a more airy and intelligible soundstage. This approach is designed for extended use, reducing the feeling of confinement often associated with closed-back headphones.
The assembly is housed in a PVD-treated stainless steel structure, ensuring good rigidity over time, while the imitation leather ear pads guarantee comfort even during long listening sessions, making it ideal for everyday use.
Product typeHeadphone
Headphone typeOpen-back
Driver diameterØ50mm
Frequency response20Hz-20kHz
Inpedance32Ω
Sensitivity98dB ± 3dB
Headphone connectors2x Jack 3.5mm
Detachable cable
ColorWood
Package1x Kiwi Ears Altruva
1x 3.5mm jack headphone cable 3m
1x 6.35mm jack adapter
ColorWood
Impedance (Ω)32
Efficiency / Sensitivity (dB)98.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
KIWI EARS ALTRUVA Open Back Dynamic Headphones 32 Ohm 98dB 20Hz-20kHz
The Kiwi Ears Altruva is an open-back circumaural headphone based on a 50 mm dynamic driver, whose PU + PEK composite diaphragm, combined with a...
