TANCHJIM RITA Headphones
The Tanchjim RITA is an over-ear Bluetooth headphone with active noise cancellation (ANC) designed to deliver a high-resolution Hi-Fi sound experience, whether you're listening on the go or at home. Equipped with 40mm dynamic speakers, LDAC-compatible Bluetooth 6.0 connectivity, a 3.5mm wired mode, and a long battery life of up to 92 hours, it meets the expectations of demanding audiophiles and everyday users alike.
Reference : 21489
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 16-06-2026.
Tanchjim RITA Closed-Back Dynamic Headphones Over-Ear ANC Bluetooth 6.0 32 Ohms 20Hz-20kHz
Photo of TANCHJIM RITA
Its elegant, minimalist design is complemented by careful ergonomics, with an adjustable headband, comfortable circumaural ear cushions, and a foldable structure for easy transport. The Tanchjim RITA combines sound quality, comfort, and versatility in a modern, high-performance headset.
Tanchjim RITA: Audiophile design
40mm dynamic speakers with beryllium coating
The Tanchjim RITA headphones feature 40 mm dynamic drivers with a PET diaphragm coated with beryllium, ensuring accurate, dynamic, and natural sound reproduction. This design delivers:
  • Deep, controlled bass
  • Detailed, balanced midrange
  • Clear, non-aggressive treble
Low harmonic distortion (0.039% @ 1 kHz) ensures faithful listening, ideal for Hi-Fi music, movies, and games.
The separate acoustic chamber design minimizes interference between front and rear waves, improving bass response, overall clarity, and passive isolation, contributing to a cleaner and more immersive soundstage.
Independent rear acoustic chamber
The Tanchjim RITA features a separate rear acoustic chamber designed to reduce internal interference and improve frequency response. This acoustic architecture optimizes:
  • Soundstage
  • Instrument separation
  • Low-frequency clarity
The result is a more airy, immersive, and precise sound, even at high volumes.
TANCHJIM RITA: audiophile design
Tanchjim RITA: Hybrid Active Noise Cancellation (ANC)
The Hybrid ANC system with dual feedback microphones analyzes external and internal sounds to effectively reduce ambient noise by up to approximately -47 dB without compromising music quality. This hybrid system combines active noise reduction and passive isolation for a quieter experience on planes, subways, or in the office.
TANCHJIM RITA: Active Noise Cancellation (ANC)
Tanchjim RITA: Audio application and customization
By downloading the Tanchjim app, users can access preset sound profiles or create their own settings via a customizable 12-band EQ, as well as DSP effects to tailor the sound to music, movies, or gaming.
TANCHJIM RITA: Audio application and customization
TANCHJIM RITA: Versatile Connectivity
Tanchjim RITA: Versatile Connectivity
Bluetooth 6.0 wireless connectivity ensures stable transmission up to 15 meters with support for AAC, SBC, and LDAC codecs, enabling high-quality wireless audio listening.
For devices without Bluetooth or to avoid latency (especially when gaming), RITA supports a 3.5mm wired connection, ensuring smooth and faithful listening at all times.
Tanchjim RITA: Battery life and power supply
Thanks to a 650mAh battery, the headphones offer up to 92 hours of listening time without ANC and approximately 51 hours with ANC enabled, which is excellent for long journeys or intensive use. Charging is via USB-C (5V/1A).
Tanchjim RITA: Design, comfort, and ergonomics
The headset features a lightweight yet sturdy construction, with soft leatherette ear cushions and high-density foam for optimal comfort even after several hours of use. The adjustable headband and multidirectional hinges enhance overall ergonomics and adaptability to different head shapes.
Overview of the Tanchjim RITA headphones
1Power
2USB-C charging port
3Volume +
4Volume -
5Play/pause
63.5mm stereo jack input
7Microphone
Product typeHeadphones
DriverDynamic Ø40mm
Diaphragm materialPET with beryllium coating
THD0.039% @ 1kHz, 94dB
Impedance32Ω
Frequency response20Hz-20kHz
Bluetooth version6.0
Supported Bluetooth codecsAAC, SBC, LDAC
Bluetooth range15m (open space, no obstacles)
RF output power20dBm (EIRP)
Phone call
Power supply5V 1A via USB-C
Battery650mAh 3.7V 2.405Wh
Battery life92 hours without ANC
51 hours with ANC
ColorWhite
Package1x Tanchjim RITA
1x USB-A to USB-C cable
1x USB to 3.5mm jack cable
ColorWhite
Impedance (Ω)32
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessYes
Cable terminationNC
Headphone / Earphone connectorWireless (Bluetooth)
Headphone / Earphone connectorJack 3.5mm
TANCHJIM RITA Closed-Back Dynamic Headphones Over-Ear ANC Bluetooth 6.0 32 Ohms 20Hz-20kHz
The Tanchjim RITA is an over-ear Bluetooth headphone with active noise cancellation (ANC) designed to deliver a high-resolution Hi-Fi sound...
