January 2025 : The selection of the month by Audiophonics
Posté le 2025-02-07 News, Monthly selection 1432
xxx
Discover the selection of the month by Audiophonics
January 2024
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights: 3E Audio A5, Truthear x Crinacle Zero Red, HiFiman Prelude, Aiyima A80, Meze Audio 105 AER, Shanling Onix Waltz XM10 LTD, the new Eversolo DMP-A6 Gen 2 streamer and the Topping Hynotone ARES distorsion pedal.
3E Audio A5
3E Audio A5
3E Audio, a recognized player in the DIY world, offers the A5, a stereo Class D amplifier designed with audiophile Hi-Fi components. The A5 amplifier is based on two TI TPA3251 chips in PBTL configuration, and two dual OPA1656 OPAs. It is therefore capable of delivering up to 2x150W at 4 ohms. In terms of connectors, the 3E Audio A5 features an RCA input, a convenient balanced XLR/Jack 6.35mm combo input and an output on speaker terminals.
279,00€ TTC (232,50€ HT)
With the Zero RED, Truthear has once again collaborated with Crinacle, renowned for its expertise in IEM, to offer a new version of the fruit of their previous collaboration. These in-ear monitors retain the dynamic dual-driver structure of their predecessors, but improve on it to deliver even lower levels of distortion. Their 17.5 ohm impedance and 117.5dB sensitivity make them easy to drive.
54,90€ TTC (45,75€ HT)
HiFiman Prelude
HiFiman Prelude
With the Prelude, HIFIMAN presents a balanced Class A headphone amplifier, based on MOSFET transistors to deliver natural sound reproduction with a high power handling capacity of 10W at 32Ω. It features 3 balanced headphone outputs on its front panel, combo XLR/JACK 6.35 TRS, XLR 4 pins and jack 4.4mm. Moreover, in addition to its headphone outputs, there are preamplified RCA and XLR outputs for use as a preamplifier within a Hi-Fi system.
2660,00€ TTC (2216,67€ HT)
Eversolo DMP-A6 GEN 2
AIYIMA A80
Aiyima unveils its A80, a compact Class D integrated amplifier packed with audiophile features and components. It's primarily based on an ESS9038Q2M DAC chip and a TPA3255D2 amplifier chip. This enables it to support high-resolution sampling rates up to PCM 32bit 384kHz and DSD256, as well as delivering up to 2x120W of power at 4 Ohms from its 48V 5A power supply.
229,00€ TTC (190,83€ HT)
AIYIMA A80
Meze Audio 105 AER
The Meze Audio 105 AER is a dynamic circumaural open-back headphone designed to deliver outstanding audiophile performance in a durable structure. In fact, the 105 AER's design is based on top-of-the-range components and materials, delivering exceptional sound quality. It incorporates two dynamic dual-diaphragm transducers, each no less than 50mm in diameter, for an extended frequency response of 5Hz-30kHz.
399,00€ TTC (332,50€ HT)
Meze Audio 105 AER
The Shanling Onix Waltz XM10 LTD is a high-performance DAP, originally introduced by the brand in its Onix Miracle package. However, this version benefits from numerous improvements, including the integration of an AKM AK4191 + AK4499EX chip combo and an AD8397 headphone amplifier chip, guaranteeing exceptional audio performance. This DAP is capable of handling sampling rates up to PCM 32bit 768kHz and DSD1024, while delivering an output power of up to 877mW at 32Ω.
899,00€ TTC (749,17€ HT)
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
