This chassis kit includes spare parts that will allow you to mount the RaspTouch ES9038Q2M housing (housing only).
This chassis kit corresponds of the spare parts for the case of the RaspTouch ES9038Q2M with Allo Kali Reclocker. In this kit you will find the different faces of the case with the holes and silkscreen prints, the frame allowing the official Raspberry Pi screen to be fixed, the screws necessary to assemble the case and a set of 4 feet.
For mounting the RaspTouch ES9038Q2M Kali, you will need to add the following accessories not supplied:
The RaspTouch was developed with the aim of offering all HiFi enthusiasts a simple, elegant, affordable and above all High Resolution compatible solution to enjoy your favorite music.
The Kali RaspTouch ES9038Q2M incorporates both a high-performance ES9038Q2M ESS ESS Audiophile DAC and an Allo Kali reclocker, reducing jitter and not degrading the audio signal.
This product is only compatible with the Raspberry Pi 3. It is not compatible with Raspberry Pi 4.
Top panel | 1x |
Bottom panel | 1x |
Screen-printed rear panel | 1x |
Frame (screen support) | 1x |
Side panels | 2x (one with hole for push button) |
Feet | 4x |
Screws and other assembling elements | - |
Useful internal dimensions of the housing (W x D x H) | 14 x 14 x 4.3cm |
