Section (mm²)
0 mm - 15 mm
Diameter (mm)
Conductors material (Cable)
Conductors Plating (Cable)
Number of conductors
Insulation material
Ground / Shielding
Shielding
Tomasz C.
arnaud m.
Exelent
Jean-Louis R.
ne chauffe plus assez
Bulk Cables
  • Speaker Cables
    Speaker Cables
    Find here all our cables for speakers and loudspeakers, sold by the meter, cut, allowing the design of your own finished cables.
  • Interconnect Cables
    Interconnect Cables
    Find here all our modulation cables, sold by meter, cut, allowing the design of your own finished cables.
  • Digital Cables
    Digital Cables
    Find here all our digital cables, sold by the meter, cut, allowing the design of your own finished cables.
  • Power Cables
    Power Cables
    Find here all our power cables, sold by the meter, cut, allowing the design of your own finished cables.
  • Hook-up Wires
    Hook-up Wires
    Find here all our wiring wires, sold by the meter, to cut, allowing the internal wiring of your devices and DIY projects.
  • Silver Gold Copper Wires
    Silver wire, OCC wire
  • Wiring Accessories
    Wiring Accessories
