TOPPING B4T6-150 Balanced Interconnect Cable 4.4mm Jack to 2x 6.35mm Jack 1.5m
-15%
The Toppig B4T6-150 is a balanced 4.4mm TRRRS male to dual 6.35mm TRS male interconnect cable designed to connect an audio source equipped with a balanced 4.4mm output to an amplifier, audio interface, or active speakers featuring balanced 6.35mm jack inputs.
Reduced price!
Reference : 22204
Limited time offer:
9,90 €tax incl.
-15%
8,42 €tax incl.
7,01 € tax excl.
Shipping date: 26-11-2026.
Topping B4T6-150 Balanced 4.4mm Jack to 2x 6.35mm Jack Interconnect Cable Shielded OFC Copper Gold-Plated 1.5m
TOPPING B4T6-150
The Topping B4T6-150 is a balanced 4.4mm TRRRS male to dual 6.35mm TRS male interconnect cable designed to connect an audio source equipped with a balanced 4.4mm output to an amplifier, audio interface, or active speakers featuring balanced 6.35mm jack inputs. Measuring 150cm in length, it features OFC (Oxygen-Free Copper) conductors combined with highly effective shielding, ensuring balanced signal transmission with extremely low noise and excellent immunity to interference. The gold-plated connectors provide reliable, long-lasting electrical contact while minimizing oxidation. Its flexible outer jacket makes cable routing easier and enhances durability against repeated handling. Ideal for taking full advantage of a balanced audio connection, the Topping B4T6-150 allows you to easily connect an audiophile digital audio player, DAC, or headphone amplifier to professional audio or HiFi equipment equipped with 6.35mm TRS inputs while preserving the integrity of the audio signal.
TOPPING B4T6-150
Technical Specifications
Product TypeBalanced interconnect cable
Connectors1x 4.4mm balanced jack
2x 6.35mm TRS jack
Connector Contact MaterialGold-plated copper
Cable ConductorOFC copper
Conductor Cross-Section0.23mm² / 24AWG
Cable Diameter3.5mm
ShieldingAluminum foil and copper braid
Length150cm
Package Contents1x Topping B4T6-150
Length (m)1.5
ShieldingYes
Section (mm²)0.23
ConnectorJack 4.4mm
ConnectorJack 6.35mm
TOPPING B4T6-150 Balanced Interconnect Cable 4.4mm Jack to 2x 6.35mm Jack Shielded OFC Copper Gold Plated 1.5m
The Toppig B4T6-150 is a balanced 4.4mm TRRRS male to dual 6.35mm TRS male interconnect cable designed to connect an audio source equipped with a...
