Tolerance (%)
1 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Rated voltage (V)
Capacitors
Pierre M.
Fonctionne
bonjour ; fonctionnement correcte , mais tassement de dynamique et quelque peu bruyant ...!
Thierry d.
éclairage vintage
Parfait pour mon ampli Scott A 436 : les Vu-mètres sont à nouveau splendides .
Remarquable avec Roon
Je l'utilise comme Endpoint sur un DAC Audio GD avec Roon sur un NUC avec RoonRock comme serveur. L'écoute est...
Capacitors
  • Polarized capacitors
  • Non-polarized capacitors
  • Capacitors accessories
  • Ref : 12091
    In Stock
    Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a more balanced presentation without the excessive brightness of other high-end capacitors exaggerating the upper parts of the audio spectrum.
    75,00 € 62,50 €Ex.
    In Stock
  • Ref : 12092
    In Stock
    85,00 € 70,83 €Ex.
    In Stock
  • Ref : 18646
    In Stock
    Capacitors JANTZEN AUDIO Alumen Z-CAP are based on the Gold Silver Z-CAP series and benefit from a more ambitious assembly in terms of tonal neutrality.
    26,90 € 22,42 €Ex.
    In Stock
  • 99,00 € 82,50 €Ex.
    In Stock
  • Ref : 19437
    In Stock
    Jantzen Audio's Amber Z-Cap capacitors are made from pure copper foil of the highest quality. They have been specially designed for the tweeter section of crossover filters for passive HiFi loudspeakers. They are also ideal for use in the midrange. Amber Z-Caps are designed to deliver a more neutral sound reproduction, with an excellent balance between...
    115,00 € 95,83 €Ex.
    In Stock
  • Ref : 19440
    125,00 € 104,17 €Ex.
    In Stock
  • Ref : 19441
    175,00 € 145,83 €Ex.
    In Stock
  • Ref : 19442
    199,00 € 165,83 €Ex.
    In Stock
  • Ref : 19443
    239,00 € 199,17 €Ex.
    In Stock
  • Ref : 19444
    295,00 € 245,83 €Ex.
    In Stock
  • Ref : 19445
    339,00 € 282,50 €Ex.
    In Stock
  • Ref : 19446
    389,00 € 324,17 €Ex.
    In Stock
  • Ref : 19447
    415,00 € 345,83 €Ex.
    In Stock
  • Ref : 19448
    499,00 € 415,83 €Ex.
    In Stock
  • Ref : 18718
    Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact and giving them better sonic properties than standard film capacitors. With a nominal voltage of 160V DC, these capacitors are also more versatile than electrolytic capacitors.
    0,80 € 0,67 €Ex.
    In Stock
  • Ref : 18719
    In Stock
    0,90 € 0,75 €Ex.
    In Stock
  • Ref : 18720
    In Stock
    1,20 € 1,00 €Ex.
    In Stock
  • Ref : 18721
    In Stock
    1,20 € 1,00 €Ex.
    In Stock
  • Ref : 18722
    In Stock
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 18723
    In Stock
    1,40 € 1,17 €Ex.
    In Stock
  • Ref : 18724
    In Stock
    1,60 € 1,33 €Ex.
    In Stock
  • Ref : 18725
    In Stock
    1,80 € 1,50 €Ex.
    In Stock
  • Ref : 18726
    In Stock
    2,00 € 1,67 €Ex.
    In Stock
  • Ref : 18727
    In Stock
    2,40 € 2,00 €Ex.
    In Stock
  • Ref : 18728
    In Stock
    2,90 € 2,42 €Ex.
    In Stock
  • Ref : 18729
    In Stock
    3,50 € 2,92 €Ex.
    In Stock
  • Ref : 18730
    In Stock
    4,00 € 3,33 €Ex.
    In Stock
  • Ref : 18731
    In Stock
    4,90 € 4,08 €Ex.
    In Stock
  • Ref : 18732
    In Stock
    6,30 € 5,25 €Ex.
    In Stock
  • Ref : 18733
    In Stock
    9,50 € 7,92 €Ex.
    In Stock
  • Ref : 18734
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 18735
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 18736
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 18737
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 18738
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 19980
    In Stock
    Jantzen Audio Cross Cap capacitors offer a high level of performance and quality at a very reasonable price. This is a versatile model, using metallized polypropylene foil.
    0,90 € 0,75 €Ex.
    In Stock
  • Ref : 19995
    0,85 € 0,71 €Ex.
    In Stock
  • Ref : 19996
    In Stock
    1,20 € 1,00 €Ex.
    In Stock
  • Ref : 19997
    0,94 € 0,78 €Ex.
    In Stock
  • Ref : 19998
    In Stock
    1,20 € 1,00 €Ex.
    In Stock
