H-HYPERBOLA HD-8907 CD Player
The H-Hyperbola HD-8907 is a CD player with built-in amplification and Bluetooth 5.0 connectivity, designed to centralise playback of physical and digital sources within a compact stereo system. It delivers 2x50W of power, utilising a stabilised Sanyo optical mechanism and a brushed aluminium chassis to ensure precise playback whilst minimising mechanical interference.
By buying this product you get 25 loyalty points
Reference : 22003
259,00 €tax incl.
215,83 € tax excl.
H-Hyperbola HD-8907 CD Player DTS HD-CD Bluetooth 5.0
Thumbnail of the H-Hyperbola HD-8907
Designed for use as a standalone home audio system or as an addition to an existing system, it combines CD, USB, Bluetooth and FM radio playback, covering all audio needs without the need for additional external sources. The inclusion of tone controls allows the sound output to be tailored to the speakers or room acoustics, ensuring consistent sound reproduction regardless of the source used.
H-Hyperbola HD-8907: Audio architecture and source playback
The HD-8907 player features a CD mechanism compatible with CD-DA, HD-CD and DTS-CD, utilising a Sanyo-designed optical unit mounted on a reinforced base to minimise micro-vibrations, thereby stabilising playback and reducing tracking errors. The unit is housed in a brushed aluminium chassis. This approach is complemented by a USB interface supporting storage devices up to 128GB, enabling direct playback of WAV, FLAC, APE and MP3 files without the need for conversion. The resume function remembers the last track being played even if playback is interrupted, ensuring uninterrupted listening.
Photo of the H-Hyperbola HD-8907 headlight assembly
Photo of the speaker outputs on the H-Hyperbola HD-8907
H-Hyperbola HD-8907: Signal amplification and reproduction
The unit features a digital amplifier stage delivering 2 x 50W, thereby enabling direct operation in a stereo configuration. This power supply and output circuit configuration ensures stable performance in the face of dynamic variations, whilst maintaining consistent signal integrity across the entire spectrum. In addition, the 3.5mm headphone Jack output features an independent volume control, allowing dedicated listening without affecting the main output level.
H-Hyperbola HD-8907: Audio processing and sound tuning
The signal processing utilises a tone control, allowing the frequency response to be adjusted to suit the room acoustics or listening preferences. Unified management of CD, USB and Bluetooth streams ensures consistent processing, maintaining a uniform sound signature regardless of the source used.
Image showing the CD tray of the H-Hyperbola HD-8907
H-Hyperbola HD-8907: System connectivity and control
The connectivity features include a stereo input and a stereo RCA line output, allowing for the integration of an external source or the routing of the signal to a third-party amplifier, while the optical and coaxial outputs enable direct transmission to an external DAC when playing a CD. This versatility extends to a front-panel USB interface dedicated to playing storage media, as well as Bluetooth 5.0 connectivity offering a range of up to 10 meters, facilitating wireless access to mobile sources, while the built-in FM radio expands listening options. The unit features a front-panel display that provides feedback on sources, tracks, and settings, allowing for clear monitoring of usage, while also being controllable via an infrared remote control, enabling remote control of playback and adjustment functions, and is compatible with a universal 100-240V power supply for seamless integration.
Overview of the front panel of the H-Hyperbola HD-8907
Specifications of the front panel of the H-Hyperbola HD-8907
1Volume control
2Opening/closing the CD tray
3Menu
4Stop
5Next track
63.5mm headphone jack
7On/off button
8Previous track
9USB Port
10Play / Pause
Overview of the back of the H-Hyperbola HD-8907
Specifications for the back of the H-Hyperbola HD-8907
1Power switch
2AUX Audio Input
3RCA audio output
4Coaxial output
5FM radio antenna
6Optical output
7Mains power input
8Right channel speaker output
9Left channel speaker output
Product typeCD Player
InputsCD Player
1x USB-A (USB flash drive up to 128 GB)
Bluetooth 5.0
FM Radio
1x RCA stéréo
Speaker terminals
1x Coaxial
1x Toslink optical port
1x Headphone jack (3.5mm)
ScreenVFD
Formats supported via USBAPE / FLAC / WAV / MP3
Supported CD formatsDTSCD / CD / MP3 / HD-CD
Frequency response55Hz-20kHz
Headphone output power2x50mW
Supply voltage100-240V
Dimensions21.5x11x33cm
Frame materialAluminium
ColorGrey
Packaging1x H-Hyperbola HD-8907
1x Remote control
1x Power cable
H-HYPERBOLA HD-8907 CD Player DTS HD-CD Bluetooth 5.0
The H-Hyperbola HD-8907 is a CD player with built-in amplification and Bluetooth 5.0 connectivity, designed to centralise playback of physical and...
