SMSL PL150 CD Player CS43198 Black
The SMSL PL150 is a CD player based on a CS43198 DAC chip, a Philips mechanism and a PLL (Phase Locked Loop) circuit for high-quality playback and conversion of your favorite CDs.
4.8 / 5
Reference : 20923
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 24-06-2026.
SMSL PL150 Lecteur CD CS43198 Black
Photo of SMSL PL150
The SMSL PL150 is a CD player based on a CS43198 DAC chip, a Philips mechanism and a PLL (Phase Locked Loop) circuit for high-quality playback and conversion of your favorite CDs. Versatile, it reads both standard CDs (Ø12cm) and mini CDs (Ø8cm), and supports numerous formats: CD, CD-R, CD-RW and MP3 CD. Connections include an analog RCA output, and two bit-perfect SPDIF coaxial and Toslink optical outputs. There are also two headphone outputs on the SMSL PL150's front panel, as well as an attractive color display and various control buttons. The balanced 4.4mm jack and 3.5mm jack headphone outputs deliver up to 2x60mW @ 32 ohm, and are accompanied by a 75-step volume control for a pleasant listening experience. The user experience is further enhanced by IR remote control. All in all, the PL150 is a versatile and, above all, high-performance device that will brighten up your music library.
SMSL PL150: A CS43198 DAC chip
The PL150's CS43198 DAC chip is a low-power audio converter offering superior audio performance. It ensures clear, optimal reproduction on all the device's outputs.
Photo of CS43198 DAC chip
SMSL PL150: Bit-perfect outputs
On the rear panel of the SMSL PL150, SPDIF coaxial and Toslink optical outputs bypass any analog distortion for connection to a DAC or integrated amplifier. These outputs bring out the most authentic details and dynamics emanating from CD media.
PL150 Bit-perfect outputs
SMSL PL150 headphone outputs
SMSL PL150: Balanced 4.4mm jack and single-ended 3.5mm jack headphone outputs
Capable of driving two headphones simultaneously, the 4.4mm jack and 3.5mm jack outputs deliver up to 2x 60mW of power at 32 ohms. They also feature a 75-step volume control for precise sound level adjustment.
SMSL PL150: Mechanical stabilization
The SMSL PL150 features highly efficient shock absorbers to withstand vibration and harsh environments.
The mechanical stabilization of the SMSL PL150
SMSL PL150 overview
SMSL PL150 overview
1Control buttons
2Screen
3Balanced 4.4mm headphone output
4Single-ended 3.5mm headphone output
5RCA output
6Toslink optical output
7Coaxial output
8Alimentation 5V 2A via jack DC
Technical charcacteristics
Product typeCD player
DAC chipCS43198
MechanismPhilips
InputCD
Outputs1x RCA output
1x Toslink optical output
1x Coaxial output
Balanced 4.4mm jack headphone output
Single-ended 3.5mm jack headphone output
Supported CD formatsCD / CD-R / CR-RW / CD MP3
Supported CD sizesStandard Ø12cm
Mini Ø8cm
Headphone output power60mW sous 32 ohm
THD+N0.001%
SNR110dB
Power5V 2A
Energy consumption4W
Standby : 0.1W
Dimensions205 x 42.8 x 144.7mm
Weight1.145kg
Package1x SMSL CD player
6 reviews
Très bon rapport qualité/prix
Très bon rapport qualité/prix , surtout couplé avec un amplificateur intégré de type "FDA".
This review has been posted for SMSL PL150 CD Player CS43198 Black
Lecteur Cd SMSL
Lecteur CD livré sans son alimentation, après conseil du SAV , j'ai mis une alimentation de de 3A 5V parfait, tout marche. connexion sur DAc Toppping en ooptique. Son mieux défini qu'en analogique.
Audiophonics touours au top.
beau petit lecteur de CD
Ce lecteur de CD très compact est d'une belle qualité technique et acoustique. très pratique, on peut le brancher sur secteur ou sur une prise USB, et écouter confortablement au casque.
Parfait pour mon usage!
Très bien
J'ai commandé cet appareil pour une tierce personne
Très satisfaite de ce produit
Merci
Excellente machine
J'ai commandé cet appareil pour une tierce personne qui ne le regrette pas du tout. Mécanique Philips (je connais bien de la cdm 4 en passant par le cdm9 puis la 12 et la pro) et une puce AD en convertion, du matériel sérieux pour un prix attractif. Petit soucis lors d'une remise en route qui ne voulait pas se dérouler comme prévu, alors un merci particulier à Greg (sav) pour sa disponibilité et gentillesse. Je recommande cet appareil et bien entendu Audiophonics.
The SMSL PL150 is a CD player based on a CS43198 DAC chip, a Philips mechanism and a PLL (Phase Locked Loop) circuit for high-quality playback and...
