THINKYA DVR108 CD Player DAC
Thinkya's DRV108 is a full-featured CD player and DAC that uses a TMC688 processor and ES9038Q2M DAC chip to upsample CDs up to PCM 384kHz and convert digital signals up to PCM 768kHz and DSD512. The DRV108 also benefits from Bluetooth 5.1 bi-directional connectivity, allowing you to enjoy the convenience of a wireless connection, whatever your system configuration.
4.5 / 5
By buying this product you get 22 loyalty points
Reference : 20932
229,00 €tax incl.
190,83 € tax excl.
Shipping date: 03-11-2026.
Thinkya DRV108 CD Player DAC ES9038Q2M 32bit 768kHz DSD512 Bluetooth 5.1
Thinkya DRV108 : Front view
Thinkya
's DRV108
Thinkya DRV108: Extensive connectivity
The DRV108 offers a wide range of connectivity options. It features XLR and RCA outputs on the analog side, as well as Toslink optical and coaxial on the digital side. But that's not all: this CD player also features a 3.5mm headphone output on the front panel, amplified by a TPA152 chip. On the digital input side, two USB-A ports are available, one for a USB drive, the other for a signal from an external device. Finally, the DRV108 is also equipped with Bluetooth 5.1 bi-directional connectivity for wireless use.
Thinkya DRV108 : Bi-Directional Bluetooth connection
Thinkya DRV108 : 3/4 view
Thinkya DRV108: ES9038Q2M DAC
To deliver the highest-quality digital-to-analog conversion possible, the DRV108 relies on an ES9038Q2M chip, handling signals up to PCM 32bit 768kHz and DSD512, and offering oversampling from CD 44.1kHz to 384kHz. The choice of ESS's DAC chip also ensures crystal-clear sound reproduction, devoid of any parasitic noise or distortion. Indeed, the DRV108 boasts a dynamic range of 133dB, an impressive signal-to-noise ratio of 129dB and distortion of -120dB.
Product typeCD Player
DAC
ProcessorTMC688
InputsCD Player
1x USB-A (USB Disk up to 32Go)
1x USB-A (USB-DAC)
Bluetooth
Outputs1x Optical Toslink
1x Coaxial
1x Single-ended stereo RCA
1x Balanced stereo XLR
1x Jack 3.5mm headphone output
Bluetooth
Bluetooth versionBluetooth 5.1 bidirectional
Supported formatsWAV / FLAC / APE / MP3 / WMA
Supported sampling ratesPCM up to 32bit 768kHz
Native DSD up to DSD512
Total harmonic distortion (THD)0.05%
Signal-to-noise ratio (SNR)> 90dB
Headphone output power2x50mW @ 32Ω
Output levelXLR: 3.5V
RCA: 1.5V
Power supply50Hz 220V AC
Consumption40W
Dimensions360 x 147 x 210mm
Weight4.1kg
ColorSilver
Package1x Thinkya DRV108
1x Infrared remote control
1x Bluetooth antenna
InputCD
OutputBluetooth
OutputOptical Toslink
OutputJack 3.5mm
OutputCoaxial SPDIF
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD512
ColorSilver
Remote ControlYes
4 reviews
Alias Silcron MaxConnect CD Player with DAC fantastic product !!!
This review has been posted for THINKYA DVR108 CD Player DAC ES9038Q2M 32bit 768kHz DSD512 Bluetooth 5.1
Great sounding player
The DVR108 sounds really good. It is easy to use, the display is big, clear and readable from a distance.
My player came with a Chinese manual only. i could read it with Google Translate; also the user interface is fairly simple so there isn't much need for a manual for most operations. The display shows English words / letters. "WELCOME" , "NO DISC", "CD" and so on. What little writing is on the remote control is also in English.
Mine also came with a Chinese power lead. The socket on the back of the player is IEC C13, the same as most PCs. I had no trouble finding a suitable power lead.
It's quite heavy and seems solidly built.
Once connected it sounds great. I have no regrets.
Thoroughly recommended.
Oh, and answering one question i had before i bought it - the volume controls only impact the headphone output,
Très bon son. Attention, produit pour marché asiatique
J'utilise ce lecteur CD via sa sortie TOSLINK avec un streamer WIIM Ultra. Côté reproduction sonore, c'est parfait, en tout cas pour moi.
La mécanique est solide, le lecteur pèse quasiment 5 kg et est très stable.
En revanche, le produit livré est pour le marché asiatique et non pas européen. Le cordon secteur est équipé d'une fiche à trois broches plates et non pas d'une fiche européenne. J'ai dû faire mes fonds de tiroir pour trouver un cordon secteur et utiliser ce lecteur.
La notice est exclusivement en chinois, donc inutilisable. J'ai trouvé une version chinois / anglais en fouillant sur internet.
Audiophonics devrait mentionner clairement ces limitations dans la fiche produit afin que le client achète, ou pas, en connaissance de cause. Au passage, la législation européenne impose que le notice soit rédigée dans la langue du pays de commercialisation...
Je retire deux étoiles à cause de ces limitations.
It is a great product for a small price.
Thinkya's DRV108 is a full-featured CD player and DAC that uses a TMC688 processor and ES9038Q2M DAC chip to upsample CDs up to PCM 384kHz and...
