TRETTITRE TTT-LP3 Bluetooth Turntable
The Trettitre TTT-LP3 is a wireless turntable designed to integrate vinyl playback into a contemporary audio setup. It supports 33⅓ and 45 RPM formats, while combining an Audio-Technica AT-3600L cartridge, a self-balancing tonearm and a built-in battery to simplify both setup and positioning of the device.
By buying this product you get 38 loyalty points
Reference : 22502
389,00 €tax incl.
324,17 € tax excl.
TRETTITRE TTT-LP3 Bluetooth 5.3 Turntable 33/45 RPM Audio-Technica AT-3600LA
TRETTITRE TTT-LP3: Front view
Suitable for both home listening and wall-mounted installation, it transmits the signal over Bluetooth 5.3 with support for the aptX HD and aptX Adaptive codecs, while retaining a 3.5 mm jack audio output for a wired connection.
Trettitre TTT-LP3: Simplified vinyl playback
The TTT-LP3 features a self-balancing tonearm system that automatically applies the appropriate pressure to the groove as soon as it is powered on. This design eliminates the usual adjustments related to tonearm balancing, tracking force and counterweight, making playback more direct for users who want a hands-on approach to vinyl without complex calibration.
The turntable supports 33⅓ and 45 RPM records, while a speed adjustment of about ±5 % allows the rotation to be fine-tuned when the recording or record requires it. This flexibility suits both everyday listening and collections that include older pressings.
TRETTITRE TTT-LP3: Set mounted on the wall
Trettitre TTT-LP3: Wireless listening and analog output
The Bluetooth 5.3 module of the TTT-LP3 supports the Qualcomm aptX HD and aptX Adaptive codecs, in order to transmit the signal to a compatible speaker or headphone with better-controlled latency and compression than a standard Bluetooth connection. The stated range reaches 10 m, allowing the turntable to be placed at a distance from the listening system.
For those who prefer a direct connection, the 3.5 mm audio output allows the connection of a headphone, an active speaker or an amplifier equipped with an analog input. This dual connectivity thus makes it possible to keep a wired setup while enjoying cable-free listening as needed.
Trettitre TTT-LP3: Built-in battery and standalone use
The turntable features a 2000 mAh battery operating at 3.7 V, rechargeable in about 2.5 hours. A full charge allows up to 6 hours of vinyl playback, or about 3 hours of lighting use alone, which makes it possible to use it away from a mains outlet.
This autonomy also facilitates wall-mounted installation: once mounted, the TTT-LP3 can stay in place with no visible power cable, while its wireless charging system with a power of 5 to 7.5 W helps maintain a clean presentation.
TRETTITRE TTT-LP3: backlighting
TRETTITRE TTT-LP3: being mounted on the wall
Trettitre TTT-LP3: Wall mounting and transport
The rear panel of the TTT-LP3 features a mounting structure allowing it to be hung directly on the wall, in a vertical position. The record then becomes a visual element in its own right, while the absence of any visible additional hardware after installation maintains a clean presentation.
To move the turntable, a silicone strap placed on its upper part offers a grip flexible enough to be held comfortably, while supporting the weight of the device. The TTT-LP3 can thus move from a wall presentation to tabletop listening without requiring a permanent installation.
Trettitre TTT-LP3: Ambient lighting
The surface of the turntable features a light panel diffusing even lighting across the entire chassis. It can be used during playback to accompany the movement of the record, or remain lit independently to turn the device into a decorative light source.
The lighting settings allow the ambiance to be adapted to the environment, while the shadows produced by the rotating record add a visual dimension to the listening experience. The turntable thus becomes an active element of the room, even when music is not playing.
Trettitre TTT-LP3: Coordinated wall installation
The Trettitre TTT-LP3 is designed to integrate with the TTT-DP3 CD player and the TTT-CP3 cassette player, forming a wall-mounted set dedicated to the various physical audio formats. The wall bracket needed to install all three devices is included in the turntable's box, which makes it possible to directly build a coherent configuration without any additional accessory.
Technical specifications
Product typeTurntable
Output1x Jack 3.5mm
Bluetooth 5.3
Playback speed33⅓ rpm
45 rpm
CartridgeAudio-Technica AT-3600LA
Headphone output power≥1mW+1mW @32Ω
Signal-to-noise ratio (SNR)≥38dB
Tracking force2.5~4.5g
Speed adjustment>5%
Battery3.7V 2000mAh
Charging time2.5h
Autonomy6h
Bluetooth codecSBC, aptX, aptX HD, aptX Adaptive
Bluetooth output level≥300mV+300mV
Supply voltage5V DC 2A
Dimensions342 x 233 x 87mm
Weight1395g
Package1x Trettitre TTT-LP3
1x Modular wall mount
1x USB-C cable
ColorSilver
Cartridge typeMM (Moving Magnet)
Rotation speed45 RPM
Rotation speed33 RPM
The Trettitre TTT-LP3 is a wireless turntable designed to integrate vinyl playback into a contemporary audio setup. It supports 33⅓ and 45 RPM...
