TRETTITRE TTT-CP3 Cassette Player
The Trettitre TTT-CP3 is a Bluetooth cassette player designed to integrate analog tapes into modern audio systems. It retains the mechanical elements characteristic of a cassette deck, notably the independent control buttons, while relying on precise signal decoding to reduce background noise and preserve the details of the recording.
Reference : 22501
99,00 €tax incl.
82,50 € tax excl.
TRETTITRE TTT-CP3 Bluetooth 5.4 Cassette Player
Trettitre TTT-CP3: Front view
Intended for physical media enthusiasts as well as users wishing to breathe new life into their collection, it combines a 3.5 mm jack audio output with Bluetooth 5.4 transmission, allowing you to listen to cassettes with a headphone or a wireless speaker.
Trettitre TTT-CP3: Mechanical controls
The TTT-CP3 uses independent mechanical buttons whose operation resembles that of piano keys. Each press produces clear physical feedback, making the playback, rewind and stop controls more precise than with soft buttons.
This design restores a tactile dimension typical of older cassette decks, while integrating it into a device designed for current uses. It thus keeps the ritual of handling the tape at the heart of the listening experience.
Trettitre TTT-CP3: In use
Trettitre TTT-CP3: Precise audio decoding
The TTT-CP3's playback circuit is designed to decode the analog signal of cassettes with precision, in order to limit background noise and preserve more details from the original recording. The rendering retains the character specific to magnetic media, while gaining in clarity and intelligibility.
This approach allows you to rediscover the sonic particularities of your old cassettes under listening conditions better suited to contemporary audio systems.
Trettitre TTT-CP3: Wireless playback
Thanks to its Bluetooth 5.4 module, the TTT-CP3 allows wireless transmission of the cassette signal to a compatible speaker or headphone. Recordings can thus join a modern setup without requiring a wired connection between the player and the listening system.
The 3.5 mm jack output nonetheless retains a direct connection for headphone listening or a more traditional analog integration, while the 1200 mAh battery ensures independent use.
Trettitre TTT-CP3 with Bluetooth speaker
Trettitre TTT-CP3, TTT-DP3 CD player and TTT-LP3 turntable mounted on the wall
Trettitre TTT-CP3: Stylish wall mounting
The TTT-CP3 is designed to integrate into a wall composition bringing together the TTT-DP3 CD player and the TTT-LP3 turntable. This combination creates a graphic and contemporary audio ensemble, where the different playback formats become an integral part of the decor while limiting floor clutter. The modular aluminum wall mount required for this configuration is supplied with the TTT-LP3 turntable.
Technical specifications
Product typeCassette player
Output1x Jack 3.5mm
Bluetooth 5.4
Compatible cassette typeType I~IV
Output power0.6W
Output levelJack 3.5mm : ≥250mV+250mV(32Ω)
Bluetooth : ≥300mV+300mV
Signal-to-noise ratio (SNR)≥53dB
Total harmonic distortion (THD)≤2%
Wow and flutter (W&F)≤0.2%
Battery3.7V 1200mAh
Recharge time2h
Autonomy8h
Supply voltage5V DC 2A
Dimensions120 x120 x 33mm
Weight400g
Package1x Trettitre TTT-CP3
The Trettitre TTT-CP3 is a Bluetooth cassette player designed to integrate analog tapes into modern audio systems. It retains the mechanical...
