By buying this product you get 26 loyalty points
The iEast AMP80 V2 is a versatile, high-performance Class D connected amplifier. It's based on a TDA7498E amplifier chip and an ESS ES9023 DAC chip, enabling it to support up to 24bit 192kHz and deliver up to 2x80W of power under a 4 ohm load. This compact little gem of technology supports WiFi, Ethernet and Bluetooth 5.0 (SBC) connections, so you can enjoy a wireless connection to a wide range of streaming platforms: Tidal, Deezer, Spotify, Youtube Music, Qobuz, Soundcloud and more. Some platforms can be accessed directly via the dedicated iEast Controller application. In addition, you can easily set up a multi-room system for a shared music experience. As for connectivity, there's a USB-A 2.0 input, a 3.5mm AUX input, a Toslink optical input, as well as a speaker terminal output and a 3.5mm jack output for subwoofer connection.
The iEast AMP80 V2 features a high-performance ESS Technologie ES9023 DAC chip and a TDA7498E amplifier chip. The AMP80 V2 supports sampling rates up to 24bit 192kHz and delivers up to 2x80W under a 4 ohm load. This small connected amplifier is therefore capable of providing sound for a fairly large space, while allowing its user to enjoy high-definition source files.
The IEST AMP80 V2 supports multiple connection methods such as WiFi, Ethernet and Bluetooth via SBC codec. Whatever the connection method, the IEST AMP80 V2 offers a reliable and stable wireless experience. Numerous streaming services are supported, whether via Airplay, Bluetooth or directly via the IEST CONTROL application.
The IEST CONTROLLER control application provides access to a wide range of functions, including multi-room synchronization, EQ adjustment, association of various iEast products and much more.
Thanks to the Multiroom function, you can stream different music in each room or a single source in sync.
| 1 | Speaker terminals |
| 2 | Jack DC power supply |
| 3 | USB-A input |
| 4 | Subwoofer output |
| 5 | AUX input 3.5mm jack |
| 6 | Toslink optical input |
| 7 | Ethernet RJ45 input |
| Specifications | |
| Product type | Connected amplifier |
| DAC chip | ES9023 |
| Amplification chip | TDA7498E |
| Inputs | 1x USB-A 1x AUX input jack 3.5mm 1x Toslink optical input Bluetooth WiFi Ethernet |
| Outputs | Speaker terminals 1x Subwoofer Jack 3.5mm output |
| Output power | 2x80W @ 4 ohm (1% THD+N) 2x60W @ 8 ohm (1% THD+N) |
| Input sensitivity | ~700 mV (full power) |
| Max. input current (RMS) | 1V |
| SNR | 90dB @ THD+N < 1%, f=1kHz, Gain=26dB |
| THD+N | < 0.1% (@ 1kHz) |
| WiFi | IEEE802.11 b/g/n 2.4GHz |
| Supported audio formats | APE, FLAC, MP3, WAV, AAC, AAC+, WMA, ALAC, AIFF |
| Compatible streaming protocols | DLNA, Airplay, Spotify Connect, Qplay |
| Supported sampling rates | PCM 24bit 192kHz |
| Resolution | 24bit 44.1kHz |
| Ethernet | 10/100M |
| Control smart-home | TCP/IP, IR |
| Bluetooth | Bluetooth 5.0 Codec : SBC |
| General | |
| Alimentation | 32V/4.75A via jack DC (AC adapter included) |
| Weight | 0.5kg |
| Dimensions | 136 × 134.8 x 45mm (connected amplifier) 160 x 65 x 33mm (AC adapter) |
| Package | 1x iEast AMP80 V2 connected amplifier 1x 32V/4.75A mains adapter 1x Remote control 1x 3.5mm jack cable 1x 3.5mm jack to RCA stereo cable 4x Banana plug |
| Input | Jack 3.5mm |
| Input | Bluetooth |
| Input | WiFi |
| Input | USB |
| Input | Optical |
| Input | RJ45 |
| Output | Speaker terminal |
| Output | Jack 3.5mm |
| Color | Gray |
| Channel | 2.1 |
| Class | Class D / T |
| Amplifier chip | TDA7498E |
| Power (W) | 80.0 |
| Remote Control | Control app |
| Remote Control | Yes |
