LYREMAN DAC-2 DAC Headphone Amplifier
New
The Lyreman DAC-2 is a desktop DAC with amplification and HDMI ARC, designed to centralize the digital sources of a Hi-Fi system. Its ES9039Q2M converter supports PCM up to 768 kHz/32 bit over USB-C and DSD up to DSD512; the coaxial, optical, HDMI ARC and Bluetooth inputs expand the connection options to the TV and wireless sources.
Reference : 22552
139,00 €tax incl.
115,83 € tax excl.
Lyreman DAC-2 DAC Headphone Amplifier ES9039Q2M 32bit 768kHz DSD512
LYREMAN DAC-2: Front view
The Lyreman DAC-2 is a desktop DAC with amplification and HDMI ARC, designed to centralize the digital sources of a Hi-Fi system. Its ES9039Q2M converter supports PCM up to 32bit 768kHz over USB-C and DSD up to DSD512; the coaxial, optical, HDMI ARC and Bluetooth inputs expand the connection options to the TV and wireless sources.
Its balanced XLR and single-ended RCA outputs allow it to be connected to various amplifiers or active speakers. On the XLR output, it offers a signal-to-noise ratio of 130 dB and a total harmonic distortion plus noise of less than or equal to 0.0001%. Bluetooth 5.4 supports the aptX Lossless, aptX HD, aptX Adaptive, LDAC, AAC and SBC codecs, while the Trigger In and Out connections ease its integration and power-on control within a living-room setup.
Technical specifications
Product typeDAC
Headphone amplifier
Inputs1x HDMI I2S
1x USB-B
1x Coaxial
1x Optical Toslink
Bluetooth 5.4
Outputs1x Single-ended RCA stereo
1x Balanced XLR stereo
1x Single-ended headphone output Jack 3.5mm
1x Balanced headphone output Jack 4.4mm
DAC chipsES9039Q2M
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
USB interfaceXMOS A316
Amplification chipOPA1612 / SGM8262
Frequency response10Hz-20kHz (±0.2dB)
Total harmonic distortion more noise (THD+N)RCA: ≤0.00015%
XLR: ≤0.0001%
Dynamic rangeRCA: 122dB
XLR: 130dB
Signal-to-noise ratio (SNR)RCA: 122dB
XLR: 130dB
Supported Bluetooth codecsaptX Lossless, aptX HD, aptX Adaptive, LDAC, AAC, SBC
Supply voltage12V DC
Dimensions155 x 162 x 50mm
Package1x Lyreman DAC-2
InputI2S via HDMI
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipES9039Q2M
Max sampling rate768kHz
Max sampling rateDSD512
LYREMAN DAC-2 DAC Headphone Amplifier ES9039Q2M 32bit 768kHz DSD512
The Lyreman DAC-2 is a desktop DAC with amplification and HDMI ARC, designed to centralize the digital sources of a Hi-Fi system. Its ES9039Q2M...
