LYREMAN DAC-1 DAC Headphone Amplifier
New
The Lyreman DAC-01 is a desktop DAC featuring USB-C, coaxial and optical inputs, designed to convert various digital sources and drive a headphone or an audio setup. Its ES9039Q2M converter accepts PCM streams up to 768 kHz/32 bits over USB-C, while its 3.5 mm single-ended and 4.4 mm balanced headphone outputs ensure integration suited to multiple configurations.
Reference : 22551
119,00 €tax incl.
99,17 € tax excl.
Lyreman DAC-1 DAC Headphone Amplifier ES9039Q2M 32bit 768kHz DSD512
LYREMAN DAC-1: Front view
The Lyreman DAC-01 is a desktop DAC featuring USB-C optical inputs, designed to convert various digital sources and drive a headphone or an audio setup. Its ES9039Q2M converter accepts PCM streams up to 768 kHz/32 bits and DSD512 over USB-C, while its 3.5 mm single-ended and 4.4 mm balanced headphone outputs ensure integration suited to multiple configurations.
The amplification delivers up to 500 mW per channel on the 3.5 mm output and 1,000 mW per channel on the 4.4 mm output into 32 Ω, allowing it to drive demanding headphones. A line output completes this versatility for connection to active speakers or an external amplifier, making the DAC-01 a central conversion point for a desktop system.
Technical specifications
Product typeDAC
Headphone amplifier
Inputs1x USB-C
1x Optical Toslink
Outputs1x stereo RCA
1x Jack 4.4mm
1x Headphone output Jack 3.5mm
1x Headphone output Jack 4.4mm
DAC chips1x ES9039Q2M
Supported sample rates
PCM 32bit 768kHz
DSD512
Output powerJack 3.5mm: ≥500mW+500mW @32Ω
Jack 4.4mm: ≥1000mW+1000m W@32Ω
Amplification chipsOPA1612 / SGM8262
Frequency response20Hz-20kHz (±0.06dB)
Dynamic rangeJack 3.5mm: 120dB
Jack 4.4mm: 127dB
Signal-to-noise ratio (SNR)Jack 3.5mm: 120dB
Jack 4.4mm: 127dB
Total harmonic distortion plus noise (THD+N)0.0002%
Supply voltage5V DC
Dimensions100 x 96 x 32mm
ColorSilver
Package1x Lyreman DAC-01
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipES9039Q2M
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
LYREMAN DAC-1 DAC Headphone Amplifier ES9039Q2M 32bit 768kHz DSD512
The Lyreman DAC-01 is a desktop DAC featuring USB-C, coaxial and optical inputs, designed to convert various digital sources and drive a headphone...
