Très bon Dac qui pilote une paire d'ampli mono NCORE en mode symétrique.
Beaucoup de détail, très droit, voix superbes.
Je recommande.
By buying this product you get 44 loyalty points
DAC Headphone Amplifier Balanced ES9038Pro XMOS Altera 32bit 768kHz DSD512
The Sabaj D5 is a solution that acts as both a DAC and a headphone amplifier. It ensures excellent performance, thanks to a careful architecture and components selected for their audio qualities. It also offers balanced outputs to integrate into all audio systems and enjoy a rich and detailed sound reproduction.
The D5's digital-to-analog conversion stage uses an excellent ESS ES9038Pro chip, known for its audio performance and its ability to reproduce transparent and neutral sound. A chip that offers particularly interesting measurements, including a dynamic range of 140dB. In addition, this chip supports high resolution streams, up to PCM 32bit 768kHz and DSD512.
All the circuits and stages of the D5 are equipped with high quality components. We find in particular an ESS ES9311 ultra low noise linear voltage regulator and a high efficiency sealed transformer, an XMOS XU208 32bit USB interface supporting 32bit 768kHz and DSD512 streams, four OPA1612 AOPs, an Altera MAX II CPLD associated with NDK oscillators as well as numerous discrete components in the headphone amplifier and the analog circuit.
| 1 | Single-ended Jack 6.35mm headphone output |
| 2 | Balanced XLR 4 polesheadphone output |
| 3 | Screen |
| 4 | IR Receiver |
| 5 | ON/OFF LED Indicator |
| 6 | Push button |
| 7 | Rotary knob |
| 8 | Balanced line XLR output |
| 9 | Single-ended line RCA output |
| 10 | Coaxial input |
| 11 | USB-B input |
| 12 | Optical Toslink input |
| 13 | I2S via HDMI input |
| 14 | Supply voltage switch |
| 15 | Power connector |
| 16 | Fuse |
| 17 | Power button |
"The Sabaj D5 is a very well-engineered DAC and headphone amplifier. It nearly outperforms every DAC I have ever tested! The ESS ES9038Pro when implemented well (which is not common) brings stunningly low levels of distortion which shows here."
| Specifications | |
| Product type | DAC Headphone amplifier |
| DAC Chip | ESS ES9038Pro |
| Inputs | 1x USB-B 1x Optical Toslink 1x Coaxial 1x I2S via HDMI |
| Outputs | 1x Balanced stereo XLR line output 1x Single-ended stereo RCA line output 1x Balanced XLR 4 poles headphone output 1x Single-ended stereo Jack 6.35mm headphone output |
| THD+N | DAC : 0.0002% headphone output : 0.001% |
| Dynamic range | XLR : 127dB RCA : 124dB |
| SNR | DAC : 120dB headphone output : 110dB |
| USB Transmission mode | Asynchronous |
| USB Compatibility | Windows 7 / 8 / 8.1 / 10 Mac OSX 10.6 or later Linux |
| Supported sampling rates | USB / I2S : PCM up to 32bit 768kHz, Native DSD Natif up to DSD512 Optical / Coaxial : PCM jusqu'à 24bit 192kHz, DSD DoP jusqu'au DSD64 |
| Headphone output power | Balanced : 1912mW @ 32Ω / 1025mW @ 64Ω / 455mW @ 150Ω / 231mW @ 300Ω Single-ended : 480mW @ 32Ω / 265mW @ 64Ω / 115mW @ 150Ω / 58mW @ 300Ω |
| General | |
| Supply voltage | 100-240VAC |
| Consumption | 8W |
| Standby consumption | 0.6W |
| Dimensions | 245 x 210 x 50mm |
| Weight | 2.5kg |
| Color | Black |
| Package | 1x Sabaj D5 1x Remote control 1x USB cable 1x Power cable |
| Input | USB |
| Input | Optical |
| Input | SPDIF |
| Input | I2S via HDMI |
| Output | RCA |
| Output | Jack 6.35mm |
| Output | XLR |
| Color | Black |
| Class | N/A |
| Remote Control | Yes |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Stephane N.
Andre R.
