SMSL D400 MK2 DAC Black
The SMSL D400 MK2 is a DAC high-end audio DAC designed to provide very high-resolution digital-to-analog conversion within a Hi-Fi system or digital audio setup.
By buying this product you get 77 loyalty points
Reference : 22488
779,00 €tax incl.
649,17 € tax excl.
Shipping date: 11-11-2026.
SMSL D400 MK2 DAC AK4191 + AK4499EX XMOS XU-316 Bluetooth LDAC 32bit 768kHz DSD512 Black
SMSL D400 MK2
The SMSL D400 MK2 is a DAC high-end audio DAC designed to provide very high-resolution digital-to-analog conversion within a Hi-Fi system or digital audio setup. It combines an AK4191 + AK4499EX conversion architecture, USB processing handled by a third-generation XMOS XU-316, a 10MHz OCXO clock with ±3 ppb stability, and an analog stage equipped with five high-end dual operational amplifiers. Compatible with PCM streams up to 32 bits/768 kHz and DSD up to DSD512, it also supports MQA and MQA-CD decoding.
Its connectivity includes USB Type-B, I²S via HDMI, Toslink optical, coaxial SPDIF, AES/EBU and Bluetooth digital inputs, while the balanced XLR and unbalanced RCA analog outputs allow it to be connected to an integrated amplifier or a power amplifier. The D400 MK2 also features configurable volume control, fixed or variable output level, as well as a DSD Bypass function.
SMSL D400 MK2: AKM Conversion, XMOS USB and OCXO Clock
The SMSL D400 MK2 is based on a conversion architecture combining an AK4191 and an AK4499EX, with a Dual Mono design using one AK4499EX per channel. This configuration is complemented by five high-end dual operational amplifiers and the proprietary CK-04 clock circuit, designed to reduce jitter. The device also integrates a 10 MHz OCXO quartz oscillator with ±3 ppb stability. For USB sources, the third-generation XMOS XU-316 controller provides asynchronous transmission and enables playback of files up to PCM 32 bits/768 kHz and DSD512. The USB, I²S, optical, coaxial and AES/EBU inputs support DSD transmission, while the optical and coaxial inputs support DoP64. The D400 MK2 also supports MQA via USB, optical and coaxial, as well as MQA-CD. In terms of performance, SMSL specifies a THD+N of 0.00006% (-124dB, unweighted) on the XLR output and 0,00008 % (-121dB, unweighted) on the RCA output, with dynamic range and signal-to-noise ratio reaching respectively 132dB in XLR and 126dB in RCA.
SMSL D400 MK2: High-Resolution Bluetooth with LDAC
The D400 MK2 integrates a Qualcomm Bluetooth chip for wireless music transmission from a smartphone, tablet or other compatible source. It supports LDAC codecs up to 24 bits/96 kHz, as well as aptX HD, aptX, SBC and AAC. Bluetooth therefore provides an additional digital input, alongside USB, optical, coaxial, AES/EBU and I²S connections.
SMSL D400 MK2: Color IPS display and intuitive controls
The D400 MK2 features an aluminum alloy chassis equipped with gold-plated input and output connectors. Its front panel incorporates a fully laminated color IPS display beneath tempered glass, showing information relating to the source and decoding format, with an independent DoP display function allowing identification of the current decoding format.
A multifunction knob allows volume adjustment, menu navigation and function selection: a short press enters the menu and confirms, while a long press exits the menu or turns the device on and off. The menu provides access to several PCM filters, two DSD filter modes, display brightness adjustment from 1 to 99 %, as well as an automatic display-off function adjustable from 5 to 60 seconds.
The supplied infrared remote control allows control of power, input selection, volume, mute, menu navigation and a configurable FN button.
SMSL D400 MK2: Color IPS Display
Overview of the SMSL D400 MK2
1Multifunction knob
2IR remote control receiver
3LED indicator
4Display
5XLR output
6Bluetooth antenna
7RCA output
8AES/EBU input
9Coaxial SPDIF input
10Toslink optical input
11USB-B input
12I2S input via HDMI
13Mains power supply
HDMI port of the SMSL D400 MK2
Technical specifications
Product typeDAC
DAC chipAK4191 + AK4499EX
USB interfaceXMOS XU316
Inputs1x USB-B
1x I2S via HDMI
1x Toslink Optical
1x Coaxial SPDIF
1x AES/EBU
Bluetooth
Outputs1x RCA
1x XLR
USB transmissionAsynchronous
USB system compatibilityWindows 7 / 8 / 8.1 / 10 / 11 (with driver)
Mac OSX 10.6 or later, Linux (without driver)
Supported sampling ratesUSB, I2S: PCM 32bit 768kHz, DSD512, MQA
Toslink Optical, Coaxial SPDIF: PCM 24bit 192kHz, MQA
Supported Bluetooth codecsAAC, SBC, aptX, aptX-HD, LDAC
Output level (Variable)RCA: 2.5Vrms
XLR: 5Vrms
Output impedanceRCA: 100 Ohms
XLR: 200 ohms
THD+NRCA: 0.00008% (-121dB, UN-WTD)
XLR: 0.00006% (-121dB, UN-WTD)
Dynamic rangeRCA: 126dB
XLR: 132dB
SNRRCA: 126dB
XLR: 132dB
Power supply100-240V AC mains
Power consumptionn<10W
Standby : <0.5W
Dimensions254 x 189 x 46mm
Weight1.9kg
Packaging1x SMSL D400 MK2
1x Remote control
1x Bluetooth antenna
1x Power cable
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipAK4191
DAC / ADC ChipAK4499EX
Max sampling rateMQA
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
SMSL D400 MK2 DAC AK4191+AK4499EX XMOS XU-316 Bluetooth LDAC 32bit 768kHz DSD512 Black
The SMSL D400 MK2 is a DAC high-end audio DAC designed to provide very high-resolution digital-to-analog conversion within a Hi-Fi system or...
