SMSL DO300 DAC ES9039MSPro XMOS XU316 Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA
SMSL's DO300 DAC, little brother of the DO200, takes the technical base while updating its components for improved performances. Its digital/analog conversion stage is now equipped with an ES9039MSPro DAC chip, capable of offering a transparent, rich and precise sound reproduction. In combination with an XMOS XU316 USB interface, the DO300 supports high sampling rates, up to 32bit 768kHz PCM, DSD512 as well as MQA and MQA-CD decoding.
By buying this product you get 52 loyalty points
Reference : 17243
529,00 €tax incl.
440,83 € tax excl.
Last items in stock !
Shipping date: 18-06-2026.
SMSL DO300
SMSL DO300 DAC ES9039MSPro XMOS XU-316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
The SMSL DO300 DAC takes the technical base of the DO200 MKII while updating its components for improved performance. Its digital/analog conversion stage is now equipped with an ES9039MSPro DAC chip, capable of offering a transparent, rich and precise sound reproduction. In combination with an XMOS XU316 USB interface, the DO300 supports high sampling rates, up to 32bit 768kHz PCM, DSD512 as well as MQA and MQA-CD decoding. The clock circuit has also been improved, the DO300 now uses the CK-03 architecture developed by the brand and allowing to reach a very low jitter level.
SMSL DO300 DAC ES9039MSPro XMOS Bluetooth 5.0 32bit 768kHz DSD512 MQA
MQA decoding
MQA (Master Quality Authenticated) is an award-winning British technology that restores the sound of the original recording. The MQA Master file is authenticated by the artists, producers or rights holders. These files are light enough to stream or download.
The DO300 includes an MQA decoder to play these files in order to provide the best possible audio quality. The device also supports the decoding of MQA-CD.
Bluetooth 5.0 - QCC5125
Particularly practical, the DO300, in addition to its connectivity, is equipped with a Bluetooth 5.0 receiver from Qualcomm. This one supports the classic codecs SBC and AAC, as well as the high quality codecs aptX, aptX-HD and LDAC, allowing to reach a restitution close to that of the CD, in wireless.
A readable and practical screen
The DO300 is equipped like its big brother with a beautiful screen, bright and readable, protected by a tempered glass window. This one clearly displays all the essential information for a comfortable use of the device.
Versatile connectivity
The back of DO300 reveals a particularly complete connectic, allowing the DAC to adapt to the great majority of audio systems. On the input side, we find USB-B, I2S via HDMI, AES/EBU, optical, coaxial and of course Bluetooth. On the output side, the DO300 provides single-ended stereo RCA and balanced stereo XLR.
1Multi-function button
2Screen
3IR receiver
4RCA output
5Bluetooth antenna
6Optical input
7Power connector
8Balanced XLR output
9AES/EBU input
10I2S HDMI input
11Coaxial input
12USB-B input
13Power button
Product typeDAC
DAc chipES9039MSPro
InputsBluetooth 5.0
1x AES/EBU
1x I2S via HDMI
1x Coaxial
1x USB-B
1x Optical Toslink
1x Balanced stereo XLR
THD+N0.00005% (-125dB)
Dynamic rangeXLR : 134dB
RCA : 128dB
SNRXLR : 134dB
RCA : 127dB
USB transmission modeAsynchrone
Supported sampling ratesUSB, I2S : PCM up to 32bit 768kHz, DSD up to DSD512
Optical, Coaxial, AES/EBU : PCM up to 24bit 192kHz, DSD DoP up to DSD64
MQA, MQA-CD
Geenral
Supply voltage100-240VAC (power cable included)
Consumption< 10W
Standby consumption< 0.5W
Dimensions / weight210*43*185mm / 1.2kg
Remote controlYes
Housing materialAluminum
Package1x SMSL DO300I
1x Remote control
1x Antenna
1x USB cable
1x Power cable
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
Remote ControlYes
Petit cr
Voi i un dac très silencieux ( surtout en mode fast linear)
Très bel équilibre tonal et scène large mais un poil de manque de profondeur.
Diaphane très faible, un très bon dac mais il y a mieux en débourser un peu plus.
This review has been posted for SMSL DO300 DAC ES9039MSPro XMOS XU316 Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA
SMSL's DO300 DAC, little brother of the DO200, takes the technical base while updating its components for improved performances. Its...
