SMSL DO400 DAC ES9039MSPRO Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 MQA-CD Silver
SMSL unveils the DO400, a powerful, high-quality DAC/headphone amplifier. It incorporates quality components such as the latest ESS ES9039MSPro chip, an XMOS XU316 USB interface, 11 OPA 1612A and the latest generation Qualcomm QCC5125 Bluetooth chip. To complete the package, an MQA decoder is integrated into the DO400, enabling it to decode high-resolution audio streams up to PCM 32bit 768kHz, DSD512 and MQA-CD.
By buying this product you get 54 loyalty points
Reference : 18138
549,00 €tax incl.
457,50 € tax excl.
Shipping date: 09-06-2026.
SMSL DO400
SMSL unveils the DO400, a powerful, high-quality DAC/headphone amplifier. It incorporates quality components such as the latest ESS ES9039MSPro chip, an XMOS XU316 USB interface, 11 OPA 1612A and the latest generation Qualcomm QCC5125 Bluetooth chip. To complete the package, an MQA decoder is integrated into the DO400, enabling it to decode high-resolution audio streams up to PCM 32bit 768kHz, DSD512 and MQA-CD. Headphone amplifier performance is also very good, thanks to the use of a PLFC circuit. The DO400's complete and varied connectivity will adapt to a wide range of configurations and input sources. SMSL has opted for an internal symmetrical circuit design, and the exterior features a large screen and a number of small aesthetic details, making this a pleasing-looking device.
ESS ES9039MSPRO DAC chip
The DO400 incorporates ESS's very high-performance ES9039MSPro DAC chip. This 32-bit, 8-channel chip is based on Hyperstream IV structure technology. It enables the DO400 to decode up to 32bit 768kHz PCM and DSD up to DSD512. It also accepts MQA streams.
Third-generation XMOS USB interface
A 16-core XMOS XU316 USB interface is integrated into the DO400, enabling it to process high-resolution streams (PCM 32bit 768kHz and DSD512) via its USB-B input port. This may be ideal for users wishing to use their computer as a source device. The interface is coupled with no less than 11 AOP1612A.
Bluetooth 5.1
A Qualcomm QCC5125 chip enables the SMSL DO400 to support AAC, SBC, aptX, aptX HD and LDAC codecs. So you can enjoy high-resolution files in wireless transmission.
A high-performance headphone amplifier
On the front of the DO400 are three headphone outputs: a balanced 4-pin XLR headphone output, a balanced 4.4mm jack output and an unbalanced 6.35mm jack output. The headphone amplifier circuit is an ultra-low distortion 4-channel PLFC circuit. It delivers over 2W output power with less than 0.0001% distortion at less than 16 ohm load. The DO400 can therefore be adapted to all types of headphones, thanks to its varied connectivity and high output power; 2x 6000mW / 16Ω, 2x 3000mW / 32Ω, 2x 700mW / 300Ω and 2x 350mW / 600Ω.
MQA decoder
The DO400's MQA decoder enables it to support MQA-CD streams via its coaxial, AES and Toslink optical inputs. This DAC therefore offers the possibility of enjoying professional audio quality, with retransmission as close as possible to the original sound recorded and edited in studio.
A low-noise power supply
SMSL has specially designed a regulated linear power supply for its DO400 DAC. This low-noise power supply powers the DO400's discrete components. Multiple low-noise power supplies are also present for the analog part of the DAC.
Remote control for total distance control
The DO400's remote control provides access to all basic functions such as volume control, play/pause/previous/next functions and input source selection.
Complete connectivity
1Screen
2Bluetooth antenna
3Volume control
46.35mm jack unbalanced headphone output
54.4mm jack balanced headphone output
6XLR 4-pin headphone output
7Unbalanced stereo RCA output
8Balanced stereo XLR output
9AES/EBU input
10Bluetooth antenna connector
11I2S input via HDMI
12Toslink optical input
13Coaxial input
14USB-B input
15IEC power connector
16Fuse slot
17Power switch
Product typeDAC
Headphone amplifier
Input1x USB
1x Coaxial
1x AES/EBU
1x Optical Toslink
1x I2S via HDMI
Bluetooth
Outputs1x Stereo RCA analog output
1x XLR stereo balanced output
1x XLR 4-pin balanced headphone output
1x 4.4mm balanced headphone jack output
1x 6.35mm unbalanced headphone jack output
Supported sample ratesPCM 32bit 768kHz, DoP64, DoP256 DSD512, MQA, MQA-CD
Output levelXLR: 5.2Vrms
RCA: 2.5Vrms
Headphone output power2x 6000mW / 16Ω
2x 3000mW / 32Ω
2x 700mW / 300Ω
2x 350mW / 600Ω
THD+NXLR: 0.00005% (-125dB, unweighted)
RCA: 0.00007% (-123dB, unweighted)
HPA: 0.00009% (-120dB, unweighted)
Dynamic rangeXLR: 133dB
RCA: 128dB
HPA: 126dB
SNRXLR: 133dB
RCA: 128dB
HPA: 126dB
Output impedanceLine outputs : 100Ω
Headphone outputs : near 0Ω
Headphone output gainBalanced: +20dB
Unbalanced: +14dB
USB transmission2.0 asynchronous
USB compatibilityWindows 7/8/9/10/11 (with driver)
Mac OS 10.6
Linux
MQA decoding MQA : USB, Optical Toslink, Coaxial, AES/EBU
MQA-CD : Optical Toslink, CoaxialAES/EBU
Supported bluetooth codecsAAC, SBC, aptX, aptX HD, et LDAC
Power consumption< 40W
Standbye power consumption< 0.5W
ColorSilver
Dimensions245 x 186 x 42mm
Weight1.45kg
Package1x DAC / Headphone amplifier DO400 SMSL
1x Power cable
1x USB-A to USB-B cable
1x Bluetooth antenna
1x Remote control
InputI2S via HDMI
InputAES/EBU
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
ColorSilver
ClassN/A
Remote ControlYes
I am very happy with it
At this price point i don't think you can do better. The ES9039 DAC chip used here is without doubt a better sounding one than the previous ES9038. The slight but obvious glare in the high frequencies of its predecessor is removed and the overall sound quality is even more transparent but more natural and pleasing at the same time. SMSL has done a very good implementation of the chip in this device, supported by a powerful and very good sounding headphone amp and a very well designed and executed output stage, capable to directly drive a power amp with surprisingly good results, practically eliminating the need of a preamp. The presence of a digital volume control instead of an analogue one is hardly noticed here.
This review has been posted for SMSL DO400 DAC ES9039MSPRO Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 MQA-CD Silver
SMSL unveils the DO400, a powerful, high-quality DAC/headphone amplifier. It incorporates quality components...
