SMSL R3 DAC Gaming Headphone Amplifier Black
New
The SMSL R3 is a USB DAC and headphone amplifier designed for gaming, Hi-Fi listening and computer audio control. It features a Cirrus Logic CS43131 conversion chip, a DSP processor and an independent 10-band equalizer, allowing the sound reproduction to be adjusted according to preferences and usage.
Reference : 22608
169,00 €tax incl.
140,83 € tax excl.
Shipping date: 27-11-2026.
SMSL R3 DAC Gaming Headphone Amplifier with Equalizer / VU Meter CS43131 32bit 384kHz Black
SMSL R3
The SMSL R3 is a USB DAC and headphone amplifier designed for gaming, Hi-Fi listening and computer audio control. It features a Cirrus Logic CS43131 conversion chip, a DSP processor and an independent 10-band equalizer, allowing the sound reproduction to be adjusted according to preferences and usage. Its interface inspired by professional mixing consoles combines physical sliders, large knobs and two independent VU meters to display the audio levels of the left and right channels. The R3 also features a microphone preamplifier with 48V phantom power and dedicated volume control, making it convenient for in-game communications.
Its connectivity includes a USB input, an optical input, an optical output and two headphone outputs: 3.5mm jack and balanced 4.4mm jack. Compatible with computers and various gaming devices, it offers a UAC 1.1 USB mode without drivers for certain consoles, in addition to UAC 2.0 mode.
Its all-aluminum chassis is designed to limit interference, while a 5V / 2A USB-C auxiliary power input helps ensure stable operation. The SMSL R3 combines audio conversion, headphone amplification, mixing controls and microphone management in a compact desktop device.
SMSL R3: CS43131 DAC for High-Resolution Audio
The SMSL R3 is based on a Cirrus Logic CS43131 converter, combined with a high-performance DSP processor. Its USB audio interface supports streams up to 32bit 384kHz, allowing compatible high-resolution audio files to be played. Its specified performance includes a total harmonic distortion plus noise (THD+N) of 0.00045%, a dynamic range of 118dB and a signal-to-noise ratio of 117dB. Channel separation is specified at 60dB with a 32Ω load. The integrated headphone amplifier delivers a specified output power of 68mW into 32 Ω, with a reference headphone impedance of 32Ω in the published specifications. Thanks to its USB and optical inputs, the R3 can be used as a desktop audio interface with a computer or compatible digital source, while providing access to sound settings directly from its front panel.
SMSL R3 : un DAC CS43131 pour profiter de l'audio haute résolution
SMSL R3: 10-Band Equalizer and VU Meters to Customize Your Sound
The SMSL R3 features an independent 10-band DSP equalizer, allowing the frequency response to be adjusted according to the headphones, the content being listened to or the user's preferences. Each band has an adjustment range of -10dB to +10dB, from bass to treble frequencies: the published information indicates coverage from 31Hz to 16kHz. This allows for various uses, such as modifying the tonal balance of headphones, emphasizing certain frequencies that are useful in gaming, or adapting the sound for music and movies. The interface follows the design principles of a digital mixing console, with physical sliders for the equalizer bands and large knobs for accessing the settings.
Two independent VU meters, dedicated to the left and right channels, display audio levels in real time. The R3 also offers quick switching between equalization modes to adapt the sound to different listening scenarios. It can therefore serve as a desktop audio control center, in addition to its DAC and headphone amplifier functions.
SMSL R3 : un égaliseur 10 bandes et des vumètres pour personnaliser votre son
SMSL R3: 48V Microphone Preamplifier and Gaming Mode for Your Gaming Sessions
For in-game voice communications, the SMSL R3 features an integrated microphone preamplifier with 48V phantom power and dedicated volume control. The microphone inputs allow you to select OFF, HO MIC and MIC 1 modes, depending on the configuration used. The 3.5mm headphone/microphone jack allows you to connect a headset equipped with a microphone, while the balanced 4.4mm headphone output is intended for listening with compatible headphones.
On the USB side, the R3 operates by default in UAC 2.0 mode and can be switched to driver-free UAC 1.1 mode, particularly for use with certain consoles such as the PlayStation 4, PlayStation 5 and Nintendo Switch. The mode can be changed by holding the "+" volume knob for approximately five seconds; the same operation returns the device to UAC 2.0 mode. In UAC 1.1 mode, the USB signal is limited to 16bit / 48kHz. Finally, the optical output allows the digital signal to be transmitted to another compatible device, making it possible to integrate the R3 into an audio chain including an external converter or decoder.
SMSL R3 : un préamplificateur micro 48V et un mode Gaming pour vos sessions de jeu
SMSL R3 Overview
Aperçu du SMSL R3
1Volume Fader
210-Band Equalizer Faders
3EQ ON/OFF Mode
4USB/OPT Input Selector
548V Phantom Power
6Microphone Selector
7VU Meter
8Volume Control
93.5mm Jack Microphone Input
103.5mm Jack Headphone Output
114.4mm Balanced Headphone Output
12Toslink Optical Output
13Toslink Optical Input
145V/2A USB-C Auxiliary Power Input
15USB-C Input
Technical Specifications
Product typeDAC Headphone Amplifier
DAC chipCS43131
Input1x USB
1x Toslink Optical
1x 3.5mm Microphone Jack
Output1x 3.5mm single-ended Jack
1x 4.4mm Balanced Jack
1x Toslink Optical
Supported sampling rateUSB : PCM up to 32bit 384kHz
Toslink Optical : PCM up to 24bit 192kHz
THD+N0.00045% (106dB)
Dynamic range118dB
SNR117dB
Channel separation60dB (32 ohms)
Supported headphone impedance32 ohms
Headphone output power68mW (32 ohm)
EQ adjustment range-10dB / +10dB
Power supply5V/2A
Dimensions100 x 24.2 x 142mm
Weight3331.31g
Package contents1x SMSL R3
1x USB-A to USB-C Cable
InputJack 3.5mm
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rate384kHz
Download
SMSL R3 DAC Gaming Headphone Amplifier with Equaliser / VUmeter CS43131 32 bit 384kHz Black
The SMSL R3 is a USB DAC and headphone amplifier designed for gaming, Hi-Fi listening and computer audio control. It features a Cirrus Logic...
