SMSL SANSKRIT 10Th MKII DAC 32bit / 768kHz DSD512 USB XMOS AK4493 Blue
This is the MKII version of SMSL Sanskrit 10th anniversary edition : an original and aesthetic device with extremely complete functionalities at a very affordable price.
4.8 / 5
Reference : 13402
115,00 €tax incl.
95,83 € tax excl.
To operate the remote control with Sanskrit, it is necessary to press the "C" key on the remote control.
SMSL Sanskrit 10th Anniversary Edition MKII
DAC XMOS, AK4493 DSD512 PCM768kHz
Compact and versatile DAC DSD256 / PCM 384kHz. Detector integrated tilt.
This is the MKII version of SMSL Sanskrit 10th anniversary edition : an original and aesthetic device with extremely comprehensive features for a very affordable price. It works with a conversion chip AKM AK4493, a USB interface XMOS and its construction follows proven circuits in high fidelity audio.
It has a rotating screen (like a smartphone) that allows it to be installed on both sides (Length / Width) without losing legibility. A second novelty lays in its power supply since the device has two USB inputs, so as to separate the power supply from data and gain in sound clarity.
SMSL SANSKRIT 10Th standard
DAC
AK4493
AK4490
THD+N
0.002%
0.005%
SNR
120dB
118dB
Sampling Rate
PCM : 768kHz / DSD512
PCM : 384kHz / DSD256
DAC tilt
Definitely designed for the high-quality sound, Sanskrit is able to decode DSD formats (DSD 512max) and PCM (768kHz).
It has all the necessary inputs to meet a complex installation and can simultaneously connect a digital audio source (computer, smartphone OTG, media center), a TV and a gaming station thanks to USB / Coaxial and Optics ports.
To facilitate installation in any type of environment, Sanskrit can be placed either on its edge or along its length. Best of all, the device has an integrated sensor allowing it to automatically orient the screen in your reading direction.
High quality audio components
DAC USB coaxial optical
The digital / analog decoding is made possible by a chip AK4493 AKM. This advanced audio component preserves transparency, finesse and details in the sound reproduction.
The AK4490 operates together with a XMOS asynchronous USB interface thant is famous for its native support of DSD streams. These chips are integrated in Sanskrit with a procession of proven electronic components from the power-supply units to NDK ultra low phase noise clocks.
With this choice of ambitious components (especially in this price range), DAC Sanskrit delivers crystal clear sound with extremely low distortion (THD + N 0.0002%), wide dynamic range of 119dB and comfortable SNR of 120dB.
Volume hardware and remote control
DAC remote volume
Finally, Sanskrit has two features that are found usually in larger, more complex and more expensive devices:
- A hardware volume control (does not damage the resolution in digital audio stream). This feature allows to connect Sanskrit directly to a power amplifier without necessarily having to go through a volume controller preamplifier.
- A remote control support. Every function can be driven remotely such as : raise / lower the volume, alternate sources ...
Double USB input
Rear Facade Sanskrit SMSL
Sanskrit is USB-powered via a Micro-USB input on its back cover.
To isolate the audio signal from the noise coming along the power supply, two USB entries are present: one dedicated to data only and the other dedicated exclusively to the power supply. Thanks to this configuration, the audio source is not in charge of powering the DAC - which is generally poor in this function - and it is quite possible to connect this USB input to a real regulated linear power supply that meets the audiophile standards to maximize your listening experience.
Review by Audio Science Review
These mini "pocket" DACs are changing the game with their excellent performance and budget prices. There is really no excuse to use sub-par DACs or spend orders of magnitude for boutique DACs with far worse performance.
 test by the measurement forum Audio Science Review
Quobuzissime award for Sanskrit 10th anniversary
"S.M.S.L offers a visually beautiful digital to analog converter with superb sound performance, among the most beautiful sound we heard."
Test Qobuz
1 - I/R Receiver
2 - Display (auto pitch)
3 - Power / selection button
4 - Analog Out RCA Stereo
5 - Coaxial Input
6 - Optical Input
7 - USB input (DATA)
8 - USB input (Power)
TypeDAC
Volume ControlYes
Output Level2.2Vrms
THD + N0.0002%
Dynamic range119dB
Signal / N ratio120dB
USB compatibilityWindows 7/8 / 8.1 / 10
Mac OS X10.6 and higher
Linux
BIT DepthUSB: 1-32bit
Coaxial / Optical: 1-24bit
Sample rateUSB PCM: 44.1 - 768kHz
USB DSD: DSD512
Optical / Coaxial: 32-192kHz
Power supplyMicro-USB 5VDC (NOT INCLUDED)
Power consumption1.5W
Quiescent currentLess than 0.1W
Dimensions75 x 45 x 144mm (width / height / depth)
Weight300g
Package Contents
1xDAC Sanskrit 10th anniversary MKII
1xRemote control (Press "C" to activate the remote control)
1xUSB-A to Micro-USB cable 1.1m
8xsilicone feet
DAC / ADC ChipAK4493EQ
Max sampling rateDSD256
Max sampling rate768kHz
ColorOther
Remote ControlYes
22 reviews
Super DAC
Très bon DAC. Rien à redire au niverau qualité du son. Seul bémol, une télécommande très "chinoise" : elle marche à conditon de ré-appuyer régulièrement sur le bouton "C". Etant donné le prix du produit, les 5 étoiles sont tout de même méritées.
This review has been posted for SMSL SANSKRIT 10Th MKII DAC 32bit / 768kHz DSD512 USB XMOS AK4493 Blue
Pas assez cher mon fils!
Et oui n'en déplaise aux irréductibles puristes qui ne jugent la qualité de leur système qu'au prix d'achat, il est possible de se faire un grand plaisir pour une somme raisonnable.
N'ayant plus de préampli, en panne, depuis longtemps, j'étais d'abord passé par un potentiomètre de volume de chez FX audio.
Moyennement satisfait de la sensibilité du réglage volume j'ai contacté Audiophonics pour des conseils. Je n'ai pas été déçu du tout et la proposition qui m'a été faite sur ce DAC prouve une fois de plus la compétence et l'écoute de cette maison.
Raccordé à une vieille platine Microméga de 25 ans d'âge en optique directement sur mon bloc de puissance Cyrus c'est une pure merveille. Aucune agressivité, tout est propre du grave aux aigus, un médium criant de vérité, une scène sonore correctement dimensionnée, belle dynamique, du détails sans en rajouter, bref que du positif. J'ai juste soigné l'alim que j'ai pris chez eux aussi, une Ifi à 49€.
Donc si votre platine CD commence à souffler beaucoup de bougies une cure de ce DAC vous redonnera la banane!
Merci Audiophonics.
Very good dac
Clean and quiet dac with spacious performance and good analysis. Easy to connect in both Windows 10 (with SMSL drivers) and Linux Ubuntu (no drivers needed).
Quick and professional communication and postage from Audiophonics.
Une petite boite magique...
Wouah !!!
Après un weekend d'écoute, à réécouter mes CDs et tester plusieurs configurations, ce petit DAC est le chainon qui manquait à mon ensemble pour lui redonner de la cohérence et enfin retrouver le plaisir d'écouter de la musique.
Il correspond exactement à ce qu'il manquait entre mon vieux Rega Planet et mon Jadis Orchestra (première génération). Idem avec mon Atoll IN80. Connecté via un simple câble optique premier prix, il est déjà extraordinaire. Il augmente la qualité des timbres, donne de la clarté dans le bas du spectre. Les basses sont enfin à la hauteur et tout est maintenant équilibré (c’est le tout petit défaut du Jadis Orchestra qui est très bon mais un peu insuffisant au niveau des basses).
En connexion USB, il est tout aussi bon. Clarté, précision et justesse des timbres sont au rendez-vous. Que ce soit en streaming ou en lecture Bitperfect (Foobar2000/Audirvana) avec des enregistrement HD, le rendu est très cohérent et neutre. Mes enceintes Atohm Eurus 1.0 se régalent.
J’avais déjà un Microméga Mydac et un HRT Musicstreamer II, dont j’étais plutôt satisfait en USB. Mais je trouvais le tout insuffisant et un peu décevant depuis que j’ai acquis les Eureus et sachant bien ce dont elles sont capables. Le SANSKRIT 10Th MKII est époustouflant.
Il me reste à tester les filtres et surtout trouver un câble optique de bonne qualité pour être, à mon avis, totalement comblé.
Bref, pour conclure…
Dans la catégorie des « petits » DAC à 100€, je pensais le Mydac au top, mais avec le SANSKRIT 10Th MKII je suis bluffé. J’ignore si je dois considérer mon ensemble comme de l’entrée de gamme ou du du haut de gamme, mais pour ceux qui ont du matériel de ce type, il n’y a pas à hésiter. Ce DAC est vraiment à la hauteur et certainement pour un bon moment.
Excellent
Sur cette installation: lecteur Foobar 2000(win 10) en Kernel stream, ce DAC, little DOT MKII avec tubes CV131 en entrée et 6N30P Sovtek en sortie, sur un K702, le son est disons ....excellent.
Aucune dureté dans les aigus, belles basses bien articulées sans exagération, les voix sont présentes, chaudes et vivante, même a niveau d'écoute modéré (attention aux oreilles quand même...)tout y est. J'ai vraiment l'impression d'écouter de très bonnes enceintes. La spatialisation est impressionnante, et on distingue parfaitement l'ambiance du local ou a été réalisé la prise de son.
J'ai testé les filtres numériques disponibles, et j'ai finalement opté pour le FL4, qui me parait le plus coherent avec mon rendu recherché, mais dans certains cas, le FL1(par défaut au déballage ) donne un rendu intéressant. Apres une semaine d'écoute on se pose vraiment la question de ce que peut apporter comme amélioration audible un materiel a 10 ou 20 fois le prix...(entre tout, y compris les tubes, j'ai investi moins de 400€....), mais je n'ai pas de reference a des niveaux de prix aussi élevés.
Dans cette gamme de prix en tout cas ,le rapport qualité /prix/plaisir me parait satisfaisant.
This is the MKII version of SMSL Sanskrit 10th anniversary edition : an original and aesthetic device with extremely complete functionalities at...
