SMSL SU-1 DAC AK4493S XMOS XU316 32bit 768kHz DSD512 MQA MQA-CD
Compact and powerful, the SMSL SU-1 DAC represents an affordable and efficient digital to analog conversion solution. Taking advantage of a careful design, it offers a great versatility while allowing a sound restitution of great quality.
4.8 / 5
Reference : 17619
79,90 €tax incl.
66,58 € tax excl.
Shipping date: 29-05-2026.
SMSL SU-1
AKM AK4493S DAC
The SMSL SU-1 is based on the use of the AKM AK4493S 32bit DAC chip, using the proprietary VelvetSound™ technology. This one allows a quality digital / analog conversion with a low level of distortion and a wide dynamic range. The result is a sound reproduction that is as rich as it is accurate for a beautiful listening experience.
XMOS XU316 USB Interface
The SU-1's USB-C input is combined with a powerful XMOS XU316 interface, efficiently processing the received audio signal. In combination with the AK4493S DAC, it allows the SMSL SU-1 to support high resolution audio streams up to PCM 32bit 768kHz and DSD512.
MQA Decoder
The SU-1 also features an MQA (Master Quality Authenticated) decoder. This format offers a very high sound quality, as close as possible to the studio recording, each file being authenticated by the artist, the producer or the copyright holder. SMSL's DAC also supports MQA-CD.
1MQA indicator
2USB indicator
3Optical indicator
4Coaxial indicator
5Stereo RCA output
6Coaxial input
7Optical Toslink input
8USB input
SMSL SU-1 review by Audio Science Review (Amir)
" SMSL cuts the functionality to minimum many need to have high quality conversion of digital to analog from multiple inputs. Performance is superb for the cost as it provides full transparency to the source. I am happy to recommend the SMSL SU-1. "
Test du SMSL SU-1 par Audio Science Review (Amir)
Product typeDAC
DAC chipAK44933S
Inputs1* USB-C
1* Optical Toslink
1* Coaxial
Outputs1* Stereo RCA
Output level2Vrms
THD+N0.00013% (-117dB)
Dynamic range121dB
SNR121dB
USB TransmissionAsynchronous
USB CompatibilityWindows 7/8/8.1/10/11
Mac OSX 10.6 or later
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, MQA 384kHz
Optical / Coaxial : PCM up to 24bit 192kHz, MQA 384kHz
Consumption< 5W
Standby consumption< 0.1W
Dimensions (L*P*H)96*78*27mm
Weight195g
Package1x SU-1
1x USB-A to USB-C cable 1m
DAC / ADC ChipAK4493S
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
35 reviews
Less Is More
Ce DAC est excellent au regard de son tarif, philosophie Less Is More : pas de bluetooth, pas d'écran, un design industriel carré mais qui inspire la solidité. Niveau connectique l'essentiel vital, par contre je note un peu de jeu dans le port fibre. Niveau son pour mon installation audiophile de premier niveau il fait mon bonheur. Pour relier un ordinateur et plus à son amplificateur sans se ruiner c'est un rapport qualité prix imbattable.
This review has been posted for SMSL SU-1 DAC AK4493S XMOS XU316 32bit 768kHz DSD512 MQA MQA-CD
DAC conforme à mes attentes
Je n'ai pas un système incroyable (ampli Scott 330RL + enceintes Merxcuriale ) mais en remplaçant une carte son bas de gamme par ce DAC SMSL et je redécouvre ma musique (lecteur CD + mediaplayer avec Qobuz)!
Rapport signal / bruit incroyable. Bon équilibre basses / mediums / aigus.
Pour le prix, c'est bluffant.
Le SU-1DAC est incroyable, mon système modeste devient audiophile.
J’ai déniché pour 20 € un ancien lecteur DVD Sony, en excellent état, avec un vrai charme vintage des années 2000 et une construction robuste. Pas de HDMI, mais des sorties optique et coaxiale, ce qui en fait une base parfaite. Je l’ai donc reconverti en lecteur CD dédié, associé à un DAC SU-1, le tout alimenté par un ampli Marantz.
Résultat : une véritable claque. Mes oreilles n’en revenaient pas. J’ai redécouvert toute ma collection de CD : les instruments sont parfaitement détachés, les voix naturelles, avec une présence presque “live”. Aucune dureté ni coloration numérique, tout reste fluide et précis. Même les basses, sans caisson, sont étonnamment profondes et bien tenues sur de petites enceintes bibliothèque Mission.
Je viens du monde audiophile et j’ai écouté (et possédé) des systèmes valant plusieurs dizaines de milliers d’euros. Et pourtant, à ce prix-là, avec ce DAC intégré à ma chaîne, le résultat est tout simplement bluffant — un véritable petit miracle musical.
Note : 9/10.
CDA
Ce produit relaye la sortie audio optique (TOSLINK) d'une télévision 4K vers un ampli NAD + enceinte JMLab (un petit hommage au créateur de cet Entreprise Française Jacques Mahul, et à son école d'ingénieur SUPELEC dont il est était issu) de bonnes factures. Je suis très satisfait de cette conversion, en tout cas il ne dénature pas cette installation audio de "moyenne_plus" gamme.
Chaine de commande impeccable pour Audiophonics pour une "première" me concernant. Il y en aura d'autres...
Perfect avec un raccordement sur un pixel
Je l'alimente et l'utilise avec du courant propre de mon smartphone avec un cable belkin 240watts.
La sortie est meilleure que sur le 5v de ma tour.
Pour la sortie Toslink a priori, c'est très bon aussi.
Le tout sur des monitors en class D.
Compact and powerful, the SMSL SU-1 DAC represents an affordable and efficient digital to analog conversion solution. Taking advantage of a careful...
