SMSL SU-3 DAC
New
The SMSL SU-3 is a compact USB digital-to-analog converter (DAC) designed to integrate a high-resolution digital source into a Hi-Fi or desktop audio system.
By buying this product you get 22 loyalty points
Reference : 22605
229,00 €tax incl.
190,83 € tax excl.
SMSL SU-3 DAC AKM AK4496 XMOS XU-316 32bit 768kHz DSD512
SMSL SU-3
The SMSL SU-3 is a compact USB digital-to-analog converter (DAC) designed to integrate a high-resolution digital source into a Hi-Fi or desktop audio system. It combines an AKM AK4496 conversion chip with an XMOS XU-316 USB audio interface, supporting PCM streams up to 32bit / 768kHz and DSD up to DSD512 via USB. It also features a 32-band PEQ parametric equalizer, whose settings are retained after the device is switched off, and two femtosecond quartz oscillators designed to provide a precise conversion clock. Its USB power supply filtering stage helps limit electrical interference. The SU-3 features USB, optical and coaxial digital inputs, as well as unbalanced RCA and balanced XLR analog outputs. The specified output levels are 2Vrms via RCA and 4Vrms via XLR. Its compact CNC-machined aluminum alloy enclosure measures 116 × 40 × 87 mm and weighs 310g. It can therefore be used with an integrated amplifier, a power amplifier or active speakers equipped with suitable analog inputs.
SMSL SU-3: AKM AK4496 DAC and High-Performance XMOS XU-316 Interface
The SMSL SU-3 uses the AKM AK4496 converter to transform digital signals into analog signals, paired with the XMOS XU-316 USB audio controller. Via USB, it supports PCM up to 32bit / 768kHz and native DSD up to DSD512, corresponding to a frequency of 22.5792MHz. The optical and coaxial inputs accept PCM streams up to 24bit / 192kHz. The manufacturer specifies a total harmonic distortion plus noise (THD+N) of 0.00012%, equivalent to -118dB. The dynamic range and signal-to-noise ratio are specified at 126dB via XLR and 123dB via RCA. Asynchronous USB audio transfer allows the DAC to manage audio data synchronization during playback. The SU-3 is therefore suitable for converting high-resolution audio files from a computer or a compatible digital source.
SMSL SU-3 : DAC AKM AK4496 et interface XMOS XU-316 haute performance
SMSL SU-3: Two Femtosecond Oscillators for a Precise Digital Clock
The SMSL SU-3 incorporates two low-phase-noise femtosecond quartz oscillators. They serve as clock references to control digital signal synchronization and reduce jitter, i.e. unwanted timing variations in clock signals. This architecture is designed to stabilize the digital-to-analog conversion process and preserve the temporal integrity of the audio signal. The oscillators work alongside the XMOS XU-316 interface and the AKM AK4496 conversion stage to process supported audio streams.
SMSL SU-3 : Deux oscillateurs femtoseconde pour une horloge numérique de précision
SMSL SU-3: 32-Band PEQ Parametric Equalizer with Settings Memory
The SMSL SU-3 incorporates a 32-band PEQ parametric equalizer, allowing precise adjustment of the audio system's frequency response. This function can be used to adapt playback to the speakers, listening room or user's preferences. Unlike simple preset equalization, a parametric equalizer allows several frequency bands to be adjusted individually and precisely. The settings are retained after the device is switched off, eliminating the need to reconfigure the equalizer each time the unit is powered on. The parameters available for each band should be checked in the software or configuration interface provided by SMSL.
SMSL SU-3 : Égaliseur paramétrique PEQ 32 bandes avec mémorisation des réglages
SMSL SU-3: USB Power Supply Filtering to Reduce Electrical Interference
The SMSL SU-3 incorporates a USB power supply filtering system designed to reduce noise, residual ripple and electromagnetic interference that may be present in the power supply. This design aims to stabilize the power supplied to the digital circuits, oscillators and converter. The DAC can operate using power supplied by the USB port, without requiring a dedicated external power adapter in a compatible USB configuration. Its power consumption is specified at less than 5W during operation and less than 0.1W in standby. The integrated filtering is designed to maintain suitable power supply conditions for audio processing while keeping the installation compact.
SMSL SU-3 : Filtrage de l'alimentation USB pour limiter les perturbations électriques
SMSL SU-3 Overview
Aperçu du SMSL SU-3
1Power Button / Source Selector
2COAX LED Indicator
3OPT LED Indicator
4USB LED Indicator
5Sampling Rate LED Indicator
6Balanced XLR Line Output
7RCA Line Output
8Coaxial Input
9Toslink Optical Input
10USB Input / Power Supply
Technical Specifications
Product typeDAC
DAC chipAK4496
USB interfaceXMOS XU316
Inputs1x USB Input
1x Toslink Optical Input
1x Coaxial SPDIF Input
Outputs1x RCA
1x Balanced XLR
Output levelRCA : 2Vrms
XLR : 4Vrms
THD+N0.00012 (-118dB)
Dynamic rangeRCA : 123dB
XLR : 126dB
SNRRCA : 123dB
XLR : 126dB
Sampling rateUSB : PCM 32bit 768kHz, DSD512
Toslink, Coaxial : PCM 24bit 192kHz
USB transmissionAsynchronous
OS compatibilityWindows 7 / 8 / 8.1 / 10 / 11
Mac OS X10.6 or later, Linux
Power consumption<5W
Standby power consumption<0.1W
Dimensions116 x 40 x 87mm
Weight310g
Package contents1x SMSL SU-3
DAC / ADC ChipAK4496
Max sampling rateDSD512
Max sampling rate768kHz
The SMSL SU-3 is a compact USB digital-to-analog converter (DAC) designed to integrate a high-resolution digital source into a Hi-Fi or desktop...
