SMSL SU2 DAC ES9039Q2M 24bit 192kHz DSD DoP64
The SMSL SU2 is a compact DAC built around audiophile-grade components. The digital-to-analog conversion is handled by an ESS ES9039Q2M DAC chip, allowing it to support streams up to PCM 24bit 192kHz and DSD DoP64 while delivering excellent technical performance, including a 130dB dynamic range and THD+N as low as 0.00006%.
Reference : 21526
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 02-06-2026.
Photo of the SMSL SU2
The SMSL SU2 is a compact DAC built around audiophile-grade components. The digital-to-analog conversion is handled by an ESS ES9039Q2M DAC chip, allowing it to support streams up to PCM 24bit 192kHz and DSD DoP64 while delivering excellent technical performance, including a 130dB dynamic range and THD+N as low as 0.00006%. A set of four OPA1612 op-amps enables the SU2 to deliver an output level of 4.7Vrms via balanced XLR and 2.3Vrms via its RCA output. In terms of inputs, it offers a full range of optical connectivity including Toslink optical, coaxial, and AES/EBU, ensuring perfect compatibility with many sources such as a CD player or digital transport.
Key features of the SMSL SU2
SMSL SU2
SMSL SU1
DAC Chip
ESS ES9039Q2M
AKM AK4493S
USB Interface
XMOS XU-316
Inputs
Toslink Optical, Coaxial SPDIF, AES/EBU
USB, Toslink Optical, Coaxial SPDIF
Outputs
RCA, XLR
RCA
MQA
Not supported
Supported
MQA-CD
Not supported
Supported
DSD
DSD DoP64
Supported
Op-Amps
4x OPA1612
1x OPA1612
Jitter Elimination Technology
CK-03 Clock Module
CK-03 Clock Module
Power Supply
AC
USB-C
SMSL SU2: LED operating indicator
On the front panel of the SMSL SU2 DAC, there is an intelligent LED indicator system that displays real-time operating information such as selected input type, sampling rate, left and right channels, and more.
SMSL SU2 LED operating indicator system
SMSL SU2 Overview
SMSL SU2 overview
1Power / Source selector
2LED indicator
3Balanced XLR output
4Single-ended RCA output
5Coaxial input
6Toslink optical input
7AES/EBU input
8AC power input
Technical Specifications
Product TypeDAC
DAC ChipESS ES9039Q2M
Op-Amps4x OPA1612A
Inputs1x Coaxial
1x Toslink optical
1x AES/EBU
Outputs1x Balanced XLR
1x Single-ended RCA
Output LevelXLR: 4.7Vrms
RCA: 2.3Vrms
THD+NXLR: 0.00006% (-123.5dB)
RCA: 0.00008% (-121.5dB)
Dynamic RangeXLR: 130dB
RCA: 126dB
SNRXLR: 130dB
RCA: 126dB
Supported Sampling RatesPCM 24bit 192kHz
DSD DoP64
Power Supply100-240V AC
Power Consumption< 2.3W
Standby Power Consumption< 0.1W
Dimensions150 x 42.5 x 133.1mm (W x H x D)
Weight532.6g
Package Contents1x SMSL SU2
1x AC power cable
InputAES/EBU
DAC / ADC ChipES9039Q2M
Max sampling rate192kHz
The SMSL SU2 is a compact DAC built around audiophile-grade components. The digital-to-analog conversion is handled by an ESS ES9039Q2M DAC chip,...
