AUDIOPHONICS Trigger Cable Male USB-A to Mono Male Jack 3.5mm 1m
Extremely practical, this USB-A to Jack 3.5mm mono trigger cable, assembled in France in our workshops, lets you control the automatic switching of your devices using the 5V signal delivered by the USB port of a computer, smartphone (adapter not supplied) or certain DACs and network players, for example
Reference : 17941
14,90 €tax incl.
12,42 € tax excl.
This product has been specially developed to work with our Audiophonics amplifiers which have a Trigger input for automatic start on.
However, it will also work with any device with a 5V trigger input.
AUDIOPHONICS Trigger cable
Male USB-A to Male mono Jack 3.5mm 1m
Audiophonics Câble Trigger USB-A Mâle vers Jack 3.5mm Mono Mâle 1m
Extremely practical, this USB-A to Jack 3.5mm mono trigger cable, assembled in France in our workshops, lets you control the automatic switching of your devices using the 5V signal delivered by the USB port of a computer, smartphone (adapter not supplied) or certain DACs and network players, for example. So there's no need to manually switch on all the devices in your system to enjoy your music.
Product typeTrigger cable
Length1m
Operating voltage5V
Connectors1* Male USB-A
1* Male mono Jack 3.5mm
Cable conductors section0.5mm² (20AWG)
Jack 3.5mm connectors contacts platingGold
Audiophionics amplifiers compatibilityMPA-S125NC RCA
HPA-S500NC
HPA-S250NC
HPA-S400NC
MPA-M400NC
MPA-S250NC XLR
MPA-S250NC RCA
MPA-M500NC
HPA-Q250NC
HPA-S400ET
MPA-M250NC
MPA-S125NC
MPA-M400ET
LPA-S500NC
HPA-T400ET
HPA-S600NC
HPA-S400ET SPARKOS EDITION
HPA-S600NCX
HPA-S300NIL
Length (m)1.0
ShieldingNC
Section (mm²)0.50
ConnectorUSB-A
ConnectorJack 3.5mm
Conductors material (Cable)N/A
Conductors Plating (Cable)Gold
3 reviews
works well
Works well with LG OLED TV B6 sending the trigger to TDAI-1120 amplifier, the 5V from the TV's USB port is sufficient and reliable to trigger waking up the amplifier
This review has been posted for AUDIOPHONICS Trigger Cable Male USB-A to Mono Male Jack 3.5mm 1m
Just works
I looked for a product like this for years and haven't seen anyone else sell one.
Affordable AVRs don't have trigger outs but they often have a USB port. Arendal Subwoofers need a trigger signal to wake up and stay on at low levels.
This cable is the solution and it works great. I just wish there were options for longer cables and 90-degree USB-connectors.
Perfect
Works perfectly. I use this cable to trigger my HPA-S250NC Power Amplifier from the USB-A output of a Minidsp SHD. Very convenient solution.
Extremely practical, this USB-A to Jack 3.5mm mono trigger cable, assembled in France in our workshops, lets you control the automatic switching of...
