FIIO GIGAS 1 Balanced Headphone Amplifier Discrete Class AB
The FIIO GIGAS 1 is a compact desktop headphone amplifier designed to deliver extremely high output power, making it suitable for driving both demanding planar headphones and high-impedance dynamic headphones.
Reference : 22247
54,90 €tax incl.
45,75 € tax excl.
FIIO GIGAS 1 Discrete Class AB Balanced Headphone Amplifier MJE243G/253G 2x 4600mW 32 Ohm
FIIO GIGAS 1
The FIIO GIGAS 1 is a compact desktop headphone amplifier designed to deliver extremely high output power, making it suitable for driving both demanding planar headphones and high-impedance dynamic headphones. Its fully discrete Class AB amplification stage is based on an op-amp + transistor current amplification architecture featuring four ON Semiconductor MJE243G transistors and four MJE253G transistors, ensuring high-current output with low output impedance. Powered either via USB-C 5V/2A or a USB Power Delivery 12V/2A power supply, the GIGAS 1 delivers up to 2 x 4600mW into 32Ω through its balanced 4.4mm jack output, while remaining compatible with headphones rated from 8 to 350Ω. It also features a 3.5mm single-ended headphone output compatible with the CTIA standard for headset microphone pass-through, as well as two analog inputs, stereo RCA and 3.5mm jack, allowing easy connection to a DAC, portable player, computer, smartphone, or CD player. Selectable gain (Low / High Gain) enables optimal output level adjustment according to the connected headphones. Its compact aluminum alloy chassis, large volume control knob, and purely analog design make it a powerful yet affordable solution for building a desktop Hi-Fi listening system.
FIIO GIGAS 1: High-Power Discrete Class AB Amplification
The GIGAS 1 features a true discrete Class AB amplifier architecture, combining an op-amp stage with a current amplification circuit based on ON Semiconductor MJE243G/MJE253G transistors. This design provides substantial current reserves and low output impedance, enabling it to drive even the most demanding headphones efficiently. Powered by a 12V PD supply, it delivers up to 4600mW per channel into 32Ω through its balanced 4.4mm output, ensuring dynamic, natural, and perfectly controlled sound reproduction.
FIIO GIGAS 1: Dual Power Supply and Versatile Connectivity
The FIIO GIGAS 1 operates with either a USB-C 5V/2A power supply or a USB Power Delivery 12V/2A power supply, the latter unlocking the amplifier's full performance. It features two analog inputs (stereo RCA and 3.5mm jack) as well as two headphone outputs (3.5mm jack and balanced 4.4mm jack), ensuring excellent compatibility with DACs, portable audio players, computers, smartphones, and CD players.
FIIO GIGAS 1: Designed for Both Hi-Fi and Gaming
Thanks to its CTIA-compatible 3.5mm jack output, the GIGAS 1 supports microphone pass-through for headsets equipped with an integrated microphone. This makes it equally suitable for Hi-Fi listening, gaming, voice calls, and multimedia applications. Its Low / High Gain selector makes it easy to use with a wide range of headphones and earphones, while the large volume knob allows precise listening level adjustment.
FIIO GIGAS 1 Overview
1Status LED
2Power switch
3Gain selector
43.5mm headphone output
54.4mm balanced headphone output
6Volume control
7USB-C power input
83.5mm input
9RCA input
Technical Specifications
Transistors4x MJE243G transistors
4x MJE253G transistors
Inputs1x 3.5mm Jack
1x RCA
Outputs1x 3.5mm headphone output (CTIA)
1x 4.4mm balanced headphone output
Supported impedance8-350 Ohm
Frequency response20Hz-200kHz (attenuation <0.4dB)
SNR≥ 118dB (A-WT)
Noise floor< 10.6uV (A-WT)
THD+N<0.00057% (1kHz/-5dB@ 32 ohm)
Output Power (4.4mm Jack, 12V Power Supply)
ImpedanceGainInput SensitivityOutput PowerOutput Voltage
16ΩHigh Gain0.77Vrms3300mW+3300mW7.3Vrms
Low Gain3.65Vrms
32ΩHigh Gain1.2Vrms4600mW+4600mW12.1Vrms
Low Gain5.7Vrms
300ΩHigh Gain1.4Vrms740mW+740mW14.9Vrms
Low Gain6.6Vrms
Output Power (3.5mm Jack, 12V Power Supply)
16ΩHigh Gain1.18Vrms2200mW+2200mW5.9Vrms
Low Gain5.5Vrms
32ΩHigh Gain1.3Vrms1400mW+1400mW6.7Vrms
Low Gain6.2Vrms
300ΩHigh Gain1.4Vrms185mW+185mW7.5Vrms
Low Gain6.6Vrms
Output Power (4.4mm Jack, 5V Power Supply)
16ΩHigh Gain0.36Vrms790mW+790mW3.6Vrms
Low Gain1.72Vrms
32ΩHigh Gain0.43Vrms580mW+580mW4.3Vrms
Low Gain2Vrms
Output Power (3.5mm Jack, 5V Power Supply)
16ΩHigh Gain0.42Vrms280mW+280mW2.1Vrms
Low Gain2Vrms
32ΩHigh Gain0.45Vrms170mW+170mW2.3Vrms
Low Gain2.1Vrms
Power supply5V 2A via USB-C
PD 12V 2A via USB-C
Dimensions132 x 60 x 40mm
Weight210g
Package contents1x FIIO GIGAS 1 Headphone Amplifier
1x USB-A to USB-C cable
InputJack 3.5mm
OutputJack 4.4mm
OutputJack 3.5mm
ClassClass A / AB
FIIO GIGAS 1 Balanced Headphone Amplifier Discrete Class AB MJE243G/253G 2x 4600 mW 32 ohms
The FIIO GIGAS 1 is a compact desktop headphone amplifier designed to deliver extremely high output power, making it suitable for driving both...
