iFi Audio Pro-iESL transformer Amplifier for Electrostatic Headphone
By buying this product you get 164 loyalty points
Reference : 12183
1 649,00 €tax incl.
1 374,17 € tax excl.
iFi Audio PRO-iESL
Adapter for electrostatic headphones iFi Audio Pro-iESL adaptateur pour casque électrostatique
Innovative and refined solution
This "energizer" transforms the classic symmetrical headphone amplifiers and integrated amplifiers into a Kingsound and Stax electrostatic headphone amplifier.
Casque électrostatique Kingsound KS-H4
Example of suggestion:Kingsound KS-H4 Headphones sold separately
This technology on Permalloy transformer is one of the best to amplify an electrostatic headphones bringing dynamic, natural sound insurmountable even in the high acute medium where traditional technologies are lacking bringing a lean and little differentiated sound even on tube amps for ESL helmets.
Cand headphone amplifier works either by plugging it into the top outputsspeakers of a standard built-in amplifier, either at the output of a balanced balanced headphone amplifierhref = "https://www.audiophonics.fr/fr/amplificateur-casque-sedentaire/ifi-audio-pro-ican-preamplificateur-amplificateur-casque-a-tubes-p-11024.html">iFi AUDIO PRO iCANfor example,Aune X7S
iFi Audio Pro-iESL
The principle of the Permalloy PPCT transformer
A Permalloy coupling transformer brings a lot of benefits to an electrostatic headset. It provides a real impedance and voltage matching on an electrostatic headset that produces a dynamic microphone from bass to treble without thinness with real homogeneity on the bandwidth.
Thes conventional transistor or tube amplification schemes are incapable of providing such coherence. Like all elegant technology, this electrostatic headphone amplifier works only on 3 steps in a clean design with few components but high quality respecting the starting signal in its integrity.
s: //www.audiophonics.com/img/cms/capacitive%20pro%20IESL.jpg "alt =" iFi Audio Pro-iESL "/>
An amplification power supply on a capacitive load
Power is the most important aspect for amplification of electrostatic headphones. the iFi Audio Capacitance Load Capacitor provides an extremely low noise level that simulates battery charging by nature without the disadvantages of discharge cycles.
the alliance of the Permalloy output transformer opposite the capacitive charge of the capacitors allows a real barrier to noise and very high frequencies allowing optimal working of electrostatic headphones.
iFi Audio Pro-iESL
High level components
This capacitive battery charge is achieved through 12 Wima Germany 1000 V capacitors. The key is the very high insulation resistance (several kilo Ohm) with minimal leakage currents. The SMD type resistors on the circuit are of Vishay MELF series origin allowing a fast impulse response without noise noises on the harmonics of the signal.
Broad electrostatic and dynamic compatibility
This amplifier casque thanks to a wide range of settings that allows the operation of a large number of ESL headphones market but also classical headphones in Balanced mode symmetrical electrodynamic. Equipped with BIAS voltage regulation and impedance, the iFi audio PRO-iESL is therefore essential with the main brands of the market:
  • Electrostatic: compatible with Kingsound, Stax, Sennheiser Orpheus, Koss
  • Electrodynamics Balanced: Sennheiser, Focal, AKG (K1000), Audeze, Beyerdynamic
Test iFi Pro-iESL par Paul Rigby
Test of IFI PRO-IESL by Paul Rigby
iFi Audio Pro-iESL
iFi Audio Pro-iESL
1x 5 pin DIN compatible new STAX PRO 500V and 600V
Outputs Headphones Analog
Normal1x 6 pin DIN compatible old STAX normal 230V BIAS
Pro
Balanced Outputs 4 Pin Dynamic Headphones 10V 64OhmAKG (K1000) AUDEZE, Sennheiser HD800, Beyerdynamic, Focal
Analog outputs
Speaker outputs on terminal blocksGold plated
Analog inputs
balanced balanced 4-pinDynamic Headphone Amplifiers
Loudspeaker terminalsCompatible amplifiers from 30W minimum to 100W maximum
ESL Link PortCompatibleiFi Audio Pro iCAN
Electrostatic headset compatibility BIAS setting
Former STAX ESHP230V (normal inputs)
Sennheiser Orpheus HE-90500V (custom inputs)
Sennheiser HE-60, Kingsound KS-H2 / 3/4540V (custom inputs)
Stax new generation Pro Bias ESHP580V (pro input)
KossESP / 950, Jade600V (custom)
620V (future option)
Frequency response5.50kHz -3dB
Max Output Voltage640V (16Ω 20V), 320V (64Ω 20V)
Input Voltage (PRO iESL)5V to 9V 1A Max
Input Voltage iPower85-265V 50 / 60Hz
<!-- CARACTÉRISTIQUES SECTION ->
Miscellaneous
Weight2.5kg
Dimensions213 x 206 x 63.3mm
InputXLR
InputSpeaker terminals
InputHDMI
OutputSpeaker terminal
OutputKingsound / Stax 5 Pin
OutputKingsound / Stax 6 Pin
ColorSilver
ClassN/A
