IFI AUDIO ZEN CAN Class A balanced Headphone amplifier 15.2V
15%
3.3 / 5
Reduced price!
Reference : 14746
Limited time offer:
199,00 €tax incl.
-15%
169,15 €tax incl.
140,96 € tax excl.
Last items in stock !
Shipping date: 16-07-2025.
Ifi Audio Zen Can
Headphone amplifier class A
The Zen Can by Ifi Audio is a headphone amplifier working in pure class A. Fully dedicated to this olny function, it has a fully analog headphone amplification circuit and is connected to your sources via 4.4mm jack connector (balanced), 3.5 jack mm and RCA (single-ended).
While looking a lot like the ZEN DAC from the same manufacturer - which is also equipped with a headphone amplifier function - the ZEN CAN stands out radically with a balanced / dual mono circuit in discrete components able to deliver a voltage up to 15V under 600 Ohms / balanced. In other words, the ZEN CAN is aimed at audiophiles who want to make sure once and for all that their audio installation is capable of driving all possible types of headphones, without distinction of power requirements or architecture (balanced/ single-ended).
Oversized power capabilities
IFI Audio ZEN CAN output stage has no less than four operational amplifiers mounted in FET mode (OV4627) working in a balanced / dual mono low impedance circuit. This allows the ZEN CAN to deliver formidable power to effortlessly drive the most difficult headset with a minimal distortion rate:
Balanced Output (THD < 1%)300Ω756mW (15.1V)
600Ω385mW (15.2V)
Single-Ended Output (THD < 1%)16Ω1000mW (4.0V)
32Ω1600mW (7.2V)
300Ω196mW (7.6V)
600Ω98mW (7.6V)
IFi Audio Circuit & features
In addition to the volume adjustable via a large and easy-to-access rotary potentiometer on the front, the ZEN CAN offers the full range of processing and correction tools developed by Ifi Audio in order to offer the best audio reproduction. XBass function, already present on devices like the Nano iCan which is designed to emphasize the low frequencies with a warmer reproduction while avoiding overloading the overall tonal balance.
It also features the 3D function, appreciated for increasing the impression of front / rear depth in the perception of sound spatialization.
Finally, the controls on the front panel allow the user to select the active input as well as to adjust the input stage gain (6dB; 12dB; 18dB; 24dB balanced / 0dB; 6dB; 12dB; 18dB unbalanced).
All treatment options can be activated and deactivated individually with ease using a menu (physical buttons) on the front panel. A microcontroller integrated into the circuit ensures that the activation and deactivation of treatments, as well as the passage from one input to another, is done silently and without any perceptible interference.
A final 200 Ohm (balanced) line output also connects the Zen Can to a power amplifier in order to allow many integration scenarios.
TypeClass A Headphone amplifier
Power output (balanced)756mW (15.1V) @ 300 Ohm, <1% THD
385mW (15.2V) @ 600 Ohm, <1% THD
Power output (single-ended)1,000mW (4.0V) @ 16 Ohm, <1% THD
1,600mW (7.20V) @32 Ohm, <1% THD
196mW (7.6V) @ 300 Ohm, <1% THD
98mW (7.6V) @ 600 Ohm, <1% THD
Frequency response20Hz-20kHz (+0dB / -0.03dB)
SNR120dB (BAL) (@ max out, A weighted)
Dynamic range120dB (BAL) (@ max out, A weighted)
THD + N< 0.0069% (BAL) (4V out, 16 Ohm, 1kHz, A weighted)
Output impedanceSorties casque : 24KΩ symétrique / 1MΩ asymétrique
Sortie ligne : 200Ω symétrique
GainSortie symétrique : 2X/6dB; 4X/12dB; 8X/18dB; 16X/24dB
Sortie asymétrique : 1X/0dB; 2X/6dB; 4X/12dB; 8X/18dB
Crosstalk-90dB
Inputs4.4mm Pentaconn (4.0V)
RCA L/R (2.0V)
3.5mm jack (1.0V)
Package contents
Ifi Audio Zen Canx1
5V 2.5A Power supplyx1
RCA to RCA cablex1
3.5mm female to 6.35mm male adapter x1
InputJack 4.4mm
InputJack 3.5mm
OutputJack 4.4mm
OutputJack 6.35mm
ColorSilver
ClassClass A / AB
4 reviews
Décevant... Pas convaincu... Avis pour les audiophiles
... Superbe petit ampli au niveau de la finition et de la restitution sonore...
Pourtant s'il invite à la sortie casque 4,4mm symétrique le souffle est prédominant à bas volume. D'autant qu'aucun gain ne soit audible///
This review has been posted for IFI AUDIO ZEN CAN Class A balanced Headphone amplifier 15.2V
Fait le job, attention aux casques basse impédance et/ou très sensibles
Je ne comprends pas les critiques formulées à l'encontre de cet appareil. pour le prix la qualité de fabrication est irréprochable.
Avec un casque très sensible (Denon AH 7200 : 25 ohms ; 105dB/mW) et un gain de 0dB il est parfaitement utilisable, sauf si on écoute à très bas volume car alors on rencontre un problème de déséquilibre des canaux : c'est le seul vrai défaut de cet ampli.
A éviter donc pour les intras et les casques sensibles et/ou à basse impédance, qui ne nécessitent pas d'ampli casque de toute façon.
Excellent amplificateur abordable
Je l'ai acheté pour l'utiliser avec deux casques de grande qualité, comme le Hifiman Sundara et le Sennheiser HD700.
Avec les deux casques, cet amplificateur offre un son chaleureux et détaillé, avec une grande dynamique et spatialité. La possibilité de l'utiliser avec l'entrée symétrique est très utile. Avec l'entrée équilibrée, le son s'améliore et augmente la puissance et l'espace.
Honnêtement, je ne comprends pas qui se plaint de la qualité de cet objet: il est très difficile de s'améliorer dans la fourchette de prix allant jusqu'à 300-400 euros.
A éviter
Voilà bien longtemps que je n’avais pas acheté un appareil aussi décevant.
4 principaux problèmes :
- avec le gain réglé sur "0", je ne peux finalement l'utiliser qu'avec mon Sennheiser HD570. Avec les autres casques (ATH-MSR7 B et SONY MDR-1A M2), le son est trop fort même avec le volume réglé au minimum ;
- même avec le Sennheiser, au début de la course du potentiomètre, il existe un déséquilibre gauche/droite
Apparemment ifi aborde ce sujet dans sa FAQ mais à propos d'un autre modèle. Je pense toutefois que l'analyse de doit pas être très différente pour le Zen CAN
https://ifi-audio.com/faqs/channel-imbalance/
- à l’exception du potentiomètre, toutes les autres touches branlochent. Ce n'est pas très gênant mais désagréable et renforce encore l’impression d’avoir un appareil complètement camelote entre les mains. Lorsque j'avais reçu le colis, je pensais qu'avec ces cliquetis métalliques, l'appareil était en pièce détachée dans la boîte (ce qui n’était heureusement pas le cas)
- le souffle est important, même avec le gain sur "0". Un peu surprenant quand même pour une société qui commercialise l'iEMatch par ailleurs.
L’objectif était utiliser mon 'ATH-MSR7B en symétrique, et c’est totalement raté.
Caractéristiques alléchantes sur le papier, et assez inattendues pour un prix aussi faible, mais in fine, cet appareil ne tient pas du tout ses promesses.
