J'avais acheté le singser sa 1 mais ce sa2 est exceptionnel.
Il s'associe très bien avec mon hifiman he6se v2.
Et mes focal.
Musicalité et autorité.
C'est singser sa 2
By buying this product you get 59 loyalty points
The Singxer SA-2 is positioned as a high-end headphone amplifier and preamplifier, fully balanced and featuring pure Class A architecture. Designed for audiophiles and users of high-performance headphones, it succeeds the highly regarded SA-1 by offering increased power and control.
Inside the chassis, Singxer has completely redesigned the power supply, circuit topology, and thermal management: a copper block and aluminum alloy heat sink ensure better heat dissipation, guaranteeing reliability and consistency during extended listening sessions. The SA-2 is a fully analog device with no audio microcontroller, which limits digital interference and prioritizes pure sound reproduction.
In terms of amplification, the Singxer SA-2 uses a four-channel independent and discrete pure Class A circuit. This purely analog amplification and its control circuits eliminate EMI interference from digital control, ensuring faithful sound reproduction.
ROHM's ultra-low noise differential input transistors in a matched SMD design ensure high consistency. The other audio transistors used offer exceptional linearity for superior performance. The power supply uses high-current, ultra-low noise LDO regulators.
The final output stage uses multi-stage current amplification, similar to the architecture of high-power amplifiers. Each channel uses two pairs of ON Semiconductor medium-power transistors with a current of 4A in a parallel output configuration, ensuring sufficiently low internal resistance and high output power. This design ensures stable performance, even during high dynamic range transitions.
The SA-2 also benefits from a comprehensive protection system against overcurrent, overload, overheating, short circuits, DC protection, power-up delay, and instantaneous disengagement of the output relay during shutdown.
The power gain is significant: up to 10W at 32Ω and 15W at 20Ω, allowing you to drive both high-impedance headphones and low-impedance models. The distortion level is extremely low: THD+N measured at -117dB at 1kHz for a load of 32Ω at 8W, and a signal-to-noise ratio (SNR) and dynamic range greater than 146dB (A-wt). The advertised bandwidth ranges from 20Hz to 80kHz ±0.1dB.
The SA-2 offers balanced (XLR) and single-ended (RCA) inputs, as well as multi-format headphone outputs: 4-pin XLR connector, balanced 4.4mm jack, and single-ended 6.35mm jack. It also has preamplifier outputs (XLR/RCA) and a “GND/LIFT” switch to eliminate ground loops in complex systems. The output impedance in Low-Z mode drops to 0.15Ω in balanced mode or 1.1Ω in unbalanced mode, ensuring very firm control of demanding headphones.
The front panel of the device remains simple and functional, with a high-end ALPS potentiometer for smooth and precise volume control. The 234 x 170 x 46 mm format and aluminum chassis reinforce the impression of quality and robustness, while facilitating integration.
| Specifications | |
| Product type | Headphone amplifier / Preamplifier |
| Amplification type | Class A |
| Inputs | 1x Balanced XLR 1x Single-ended RCA |
| Outputs | 1x Balanced XLR 1x Single-ended RCA 1x Balanced Jack 4.4mm headphone output 1x Balanced XLR 4 pins headphone output 1x Single-ended Jack 3.5mm headphone output |
| THD+N (single-ended output) | 1% |
| Noise level | 0.66µV @ Max output level, SNR/DNR 147dB 300nV RMS @ Low gain, A-weighting, 20Hz-22kHz |
| SNR | 147dB |
| Output power (Balanced output) | 2x560mW @ 600Ω 2x1120mW @ 300Ω 2x2800mW @ 120Ω 2x5500mW @ 60Ω 2x10000mW @ 32Ω 2x15000mW @ 20Ω 2x13000mW @ 16Ω |
| Output power (Single-ended output) | 2x140mW @ 600Ω 2x280mW @ 300Ω 2x660mW @ 120Ω 2x2300mW @ 60Ω 2x3500mW @ 20Ω |
| Gain level | Single-ended input → Single-ended output: Low gain = 0dB / High gain = 12.8dB Single-ended input → Balanced output: Low gain = 6dB / High gain = 18.8dB Balanced input → Single-ended output: Low gain = -6dB / High gain = 6.8dB Balanced input → Balanced output : Low gain = 0dB / High gain = 12.8dB |
| Input impedance | Single-ended: 33kΩ Balanced: 20kΩ |
| Input sensitivity | Balanced input → Balanced output: High gain: 4.2Vrms Balanced input → Single-ended output: Low gain: 18Vrms Single-ended input → Balanced output: Low gain: 9Vrms Single-ended input→ SBalanced output: High gain: 2.1Vrms |
| Output impedance | Low output impedance mode: 1.4Ω (balanced) / 0.7Ω (single-ended) High output impedance mode : 11.4Ω (balanced) / 10.7Ω (single-ended) |
| General | |
| Supply voltage | 100-240VAC, 50/60Hz |
| Dimensions | 234 x 170 x 46mm |
| Housing material | Aluminum |
| Weight | 1.8kg |
| Color | Black |
| Package | 1x Singxer SA-2 1x Power cable |
| Input | XLR |
| Input | RCA |
| Output | RCA |
| Output | Jack 6.35mm |
| Output | XLR |
| Output | Jack 4.4mm |
| Color | Black |
| Class | Class A / AB |
| Remote Control | No |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jean Charles a.
