SMSL H200 Balanced Headphone Amplifier Preamplifier
The SMSL H200 is a fully balanced audiophile headphone amplifier and preamplifier based on a discrete amplification architecture integrating four proprietary PLFC (Precision Linear Feedback Circuit) modules.
By buying this product you get 40 loyalty points
Reference : 22360
409,00 €tax incl.
340,83 € tax excl.
Shipping date: 17-11-2026.
SMSL H200 Balanced Discrete Headphone Amplifier Preamplifier with PLFC
SMSL H200
The SMSL H200 is a fully balanced audiophile headphone amplifier and preamplifier based on a discrete amplification architecture integrating four proprietary PLFC (Precision Linear Feedback Circuit) modules. This design achieves an ultra-low total harmonic distortion of just 0.00007% (THD+N), a 131dB signal-to-noise ratio, and a 131dB dynamic range. Powered by a custom toroidal transformer combined with a low-noise regulated linear power supply, the H200 delivers up to 5W into 32Ω through its balanced 4.4mm headphone output, allowing it to drive both sensitive in-ear monitors and demanding audiophile headphones. It features unbalanced RCA and balanced XLR analog inputs, as well as RCA and XLR preamplifier outputs for seamless integration into a HiFi system or active speaker setup. Three gain levels allow precise output adjustment for different headphones, while the relay-controlled volume circuit ensures accurate channel matching. Housed in an elegant CNC-machined aluminum chassis with a color IPS display and remote control, the SMSL H200 is a high-performance audiophile solution for both headphone amplification and high-fidelity preamplification.
SMSL H200: Fully Balanced PLFC Discrete Architecture
The SMSL H200 features a fully balanced architecture built around four discrete PLFC (Precision Linear Feedback Circuit) modules developed by SMSL. This design significantly reduces distortion and noise while delivering an exceptionally transparent and dynamic sound reproduction. Combined with a regulated linear power supply driven by a dedicated toroidal transformer, it ensures excellent operating stability and consistent performance under all listening conditions.
SMSL H200: High Output Power and Precise Headphone Control
With up to 5W of output power into 32Ω via its balanced 4.4mm output, the H200 is capable of driving a wide range of headphones, from low-impedance models to the most demanding audiophile designs. Three selectable gain levels optimize performance for different headphones, while the relay-controlled volume circuit provides outstanding precision and perfect channel balance, even at low listening levels.
SMSL H200 Overview
SMSL H200 Overview
14.4mm Headphone Output
26.35mm Headphone Output
3Multifunction Button
4IR Receiver (Remote Control)
5LED Indicator
6Display
7XLR Input
8RCA Input
9RCA Output
10XLR Output
11Ground Lift Switch
12Ground Terminal
13USB-C Firmware Update Port
14AC Power Input (100-240V AC)
Test of the SMSL H200 by Audio Science Review
"To be honest, when measuring this preamp, I reached several times the limits of what I can safely measure, especially at lower output volumes, good on the H200. And I saw many times people talking about fact that a preamplifier should be "a straight wire with gain". And I've seen many reviews giving that appraisal to preamplifiers far from delivering as this one does...
So, Ladies and Gentleman, here you go: a straight wire with gain. Well done to SMSL at that price point."
Technical Characteristics
Product TypeHeadphone Amplifier
Preamplifier
Inputs1x RCA
1x XLR
Outputs1x RCA
1x XLR
1x 6.35mm Headphone Output
1x 4.4mm Headphone Output
4.4mm Headphone Output Power4W @ 16 Ohms
5W @ 32 Ohms
1000mW @ 300 Ohms
500mW @ 600 Ohms
6.35mm Headphone Output Power2.5W @ 16 Ohms
2W @ 32 Ohms
300mW @ 300 Ohms
600mW @ 600 Ohms
SNR131dB
Dynamic Range131dB
THD+N-122dB, 0.00007% (1kHz, 150 Ohms)
Input Impedance47kΩ
Amplifier Output ImpedanceNear 0 Ohms
Pre-Out Output ImpedanceBalanced: 44 Ohms
Unbalanced: 22 Ohms
Frequency Response20Hz - 100kHz (-0.5dB)
GainBalanced: Low (-3.5dB), Middle (6dB), High (19.7dB)
Unbalanced: Low (-9.5dB), Middle (0dB), High (13.7dB)
Power Supply100-240V AC
Power Consumption<60W
Dimensions200 x 47.9 x 174.5mm
Weight1.2kg
Package Contents1x SMSL H200
1x Remote Control
1x AC Power Cable
InputXLR
OutputJack 4.4mm
OutputJack 6.35mm
ColorSilver
Remote ControlYes
SMSL H200 Balanced Headphone Amplifier Preamplifier Discrete PLFC
The SMSL H200 is a fully balanced audiophile headphone amplifier and preamplifier based on a discrete amplification architecture integrating four...
