TOPPING DX1 II DAC Headphone Amplifier Silver
New
The Topping DX1 II is a DAC and headphone amplifier based on an ESS ES9039Q2M conversion architecture combined with an XMOS XU316 interface, designed to deliver precise digital reproduction and controlled amplification in a compact form factor. It supports PCM streams up to 384kHz and DSD256, whilst delivering 0.00007% distortion and a dynamic range of 128 dB, utilising a low-noise design with minimal crosstalk to preserve signal integrity throughout the entire system.
Reference : 21942
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 24-06-2026.
Topping DX1 II DAC Headphone Amplifier ES9039Q2M 32bit 384kHz DSD256 Silver
Topping DX1 II : Front view
It combines four-channel balanced amplification delivering up to 2x1000mW under 32Ω with a configurable 10-band equaliser, allowing you to fine-tune the sound reproduction to suit your equipment and personal preferences.
Topping DX1 II: ESS DAC chip
The Topping DX1 II features an ES9039Q2M DAC chip paired with an XMOS XU316 USB interface, enabling it to process PCM streams up to 384kHz and DSD256 whilst ensuring stable digital data transmission. This architecture is based on low-distortion conversion (0.00007% THD+N) and a dynamic range of 128dB, ensuring precise reproduction of subtle details whilst maintaining an extremely low noise level; added to this is a crosstalk figure of -140 dB, contributing to precise channel separation and a stable stereo image.
Topping DX1 II : XMOS 316 Interface
Topping DX1 II: 10-band equaliser
The DX1 II features a 10-band equaliser accessible via the TOPPING Home web interface, allowing for fine-tuning of the frequency response whilst enabling the saving and sharing of user profiles, making it easy to adapt to different headphones or sound signatures. This approach is extended by compatibility with the TOPPING Tune software locally, offering direct control of equalisation settings without relying on a network interface.
Topping DX1 II : 10-band EQ
Topping DX1 II : USB-C port
Topping DX1 II: Extended compatibility
The DX1 II features a USB-C interface that combines both power and audio signals, thereby minimising the number of connections whilst reducing the risk of unwanted ground loops. This focus on compatibility is extended with a switchable UAC 1.0 and 2.0 mode, allowing use with a variety of sources, including games consoles, whilst ensuring immediate device recognition, while the 3.5 mm TRRS headphone output extends compatibility to headsets by integrating microphone signal management.
Topping DX1 II: Balanced headphone amplification
The amplifier stage is based on a four-channel architecture that enables a balanced topology, resulting in better channel separation and reduced internal interference. It delivers up to 2 x 1000 mW under 32 Ω via 3.5 mm and 4.4 mm jack outputs, enabling it to drive a wide variety of headphones whilst maintaining a stable dynamic headroom, whilst the two-stage gain control adapts the amplification behaviour to the sensitivity of the drivers.
Topping DX1 II : with headphones
Product typeDAC
Headphone amplifier
Inputs1x USB-C
1x Optical SPDIF
Outputs1x Optical SPDIF
1x Stereo RCA
1x Jack 4.4mm
1x 3.5mm headphone jack
1x 4.4mm headphone jack
DAC chipES9039Q2M
Supported sampling ratesOptical : PCM 24bit 192kHz / DSD64 DoP
USB : PCM 32bit 384kHz / DSD256
RCA line output specifications
Total harmonic distortion more noise (THD+N)0.00009% @ 1kHz, A-wt
0.0008% @ 20-20kHz, 90kBW
Signal-to-noise ratio (SNR)125dB
Dynamic range125dB
Frequency response20Hz-20kHz (±0.1dB)
20Hz-40kHz (±0.3dB)
Output level2.4Vrms @ 0dBFS
Noise level≤ 1.3µVrms
Crosstalk-126dB @ 1kHz
Channel balance0.3dB
Output impedance50Ω
Jack 4.4mm line output specifications
Total harmonic distortion more noise (THD+N)0.00007% @ 1kHz, A-wt
0.0005% @ 20-20kHz, 90kBW
Signal-to-noise ratio (SNR)128dB
Dynamic range128dB
20Hz-40kHz (±0.3dB)
Output level5.1Vrms @ 0dBFS
Noise level≤ 2µVrms
Crosstalk-140dB @ 1kHz
Output impedance100Ω
Jack 3.5mm headphone specifications
Total harmonic distortion more noise (THD+N)0.0005% @200mW, 32Ω / 1kHz, A-wt
0.00015% @22mW, 300Ω / 1kHz, A-wt
0.002% @200mW, 32Ω 20-20kHz, 45kBW
0.0003% @22mW, 300Ω 20-20kHz, 45kBW
Dynamic range125dB
20Hz-40kHz (±0.3dB)
Output level2.3Vpp @G=L, 11.5Vpp @G=L
0.8Vrms @G=L, 4.0Vrms @G=L
0.3dBu @G=L, 14.4dBu @G=L
Noise level≤0.9µVrms @G=L
≤1.9µVrms @G=L
Crosstalk-102dB
GainG=L : -1.6dB (Vrms/FS)
G=H : 12.4dB (Vrms/FS)
Output impedance≤1Ω
Output power2x800mW @16Ω
2x510mW @32Ω
2x260mW @64Ω
2x58mW @300Ω
2x29mW @600Ω
Load impedance>8Ω
Jack 4.4mm headphone specifications
Total harmonic distortion more noise (THD+N)0.001% @850mW, 32Ω / 1kHz, A-wt
0.0001% @90mW, 300Ω / 1kHz, A-wt
0.005% @850mW, 32Ω 20-20kHz, 45kBW
0.0003% @90mW, 300Ω 20-20kHz, 45kBW
Dynamic range128dB
20Hz-40kHz (±0.3dB)
Output level4.6Vpp @G=L, 23.0Vpp @G=L
1.6Vrms @G=L, 8.1Vrms @G=L
6.3dBu @G=L, 20.4dBu @G=L
Noise level≤1.2µVrms @G=L
≤3.3µVrms @G=L
Crosstalk-140dB
GainG=L : 4.4dB (Vrms/FS)
G=H : 18.4dB (Vrms/FS)
Output impedance≤2Ω
Output power2x730mW @16Ω
2x1000mW @32Ω
2x1000mW @64Ω
2x230mW @300Ω
2x115mW @600Ω
Load impedance>8Ω
Dimensions100 x 100 x 32mm
ColorSilver
Package1x Topping DX1 II
1x Remote control
1x USB-C to USB-A cable
1x USB-C cable
OutputJack 3.5mm
OutputJack 4.4mm
OutputOptical Toslink
DAC / ADC ChipES9039Q2M
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
ClassN/A
Remote ControlYes
TOPPING DX1 II DAC Headphone Amplifier ES9039Q2M 32bit 384kHz DSD256 Silver
The Topping DX1 II is a DAC and headphone amplifier based on an ESS ES9039Q2M conversion architecture combined with an XMOS XU316 interface,...
