XDUOO TA-26S Tube balanced Headphone Amplifier / Preamplifier 6N8P 6N5P
The TA-26S from xDuoo is a tube headphone amplifier, with a nice design that reveals a smooth, warm and accurate sound. It embarks for that a 6N8P tube for the preamplification stage and a 6N5P tube for its buffer.
By buying this product you get 30 loyalty points
Reference : 17482
309,00 €tax incl.
257,50 € tax excl.
Shipping date: 16-07-2025.
xDuoo TA-26S
Tube Headphone Amplifier / Pre Amplifier 6N8P 6N5P
xDuoo TA-26S Amplificateur Casque à Tubes / Pre amplificateur 6N8P 6N5P
The TA-26S from xDuoo is a tube headphone amplifier, with a nice design that reveals a smooth, warm and accurate sound. It embarks for that a 6N8P tube for the preamplification stage and a 6N5P tube for its buffer. The input is on RCA connectors and the headphone outputs are 6.35mm jack and 4.4mm balanced jack. The TA-26S also has a pre-out RCA output to accompany an external amplifier or active speakers. All the outputs also benefit from the volume control of the device. Finally, all the components are integrated in a sturdy grey aluminum alloy case.
Compared to the XDUOO TA-26 wich has one jack ouput of 6.35mm, the XDUO TA-26S has 2 heaphones jack output of 4.4mm balanced and 6.35mm, also it has a backside power switch.
TubesPreamplifier : 6N8P
Buffer : 6N5P
Input1x Stereo RCA
Outputs1x Jack 4.4mm balanced headphone output
1x Jack 6.35mm headphone output
1x Stereo RCA
Output power500mw @ 600/300Ω
Frequency response10Hz-30kHz (±0.5dB)
Gain+16dB
SNR110dB
THD+N≤ 0.1% (1kHz)
Recommended headphone impedance60-600Ω
Supply voltage220-240VAC (Power cable included)
Dimensions250 x 110 x 160cm
Weight3.9kg
ColorGray
OutputJack 6.35mm
OutputJack 4.4mm
ColorGray
ClassTube amp
3 reviews
Bonne amplis casque
Fonctionne très bien, bon sons avec un caque SIVGA SV023.
tubes de remplacement Svetlana 6H13C et Electro-Harmonix 6SN7. Jutilise le DAP MECHEN M30 et un cable FURUTECH ADLID-35R. Le tout donne un très bon rendue audio.
Attention la couleur de l'amplis et un bleu/gris.
Le tube 6N8P et le petit tube ET le grand tube et le 6N5P.
Faite attention a la compatibilité des tubes de remplacement, il y a beaucoup de bêtises sur internet.
Nom européen (6N8P- 6SN7) (6N5P-6AS7). Bonne musique.
This review has been posted for XDUOO TA-26S Tube balanced Headphone Amplifier / Preamplifier 6N8P 6N5P
Le son et l’esthétique !
Je connaissais déjà, depuis plusieurs années, le très joli petit ampli xDuoo TA-02 d’excellente qualité. J’avais changé les tubes pour une amélioration sonore et j’écoute encore de la musique avec lui de temps à autre.
Avec le xDuoo TA-26S c’est un peu un autre monde. L’ampli est lourd et de belle dimension. Construction sérieuse, aucune radiation autour de l’ampli. La dimension des tubes, la couleur grise légèrement métallisée et le bouton rouge ajoutent quelques touches particulières à une esthétique classique revisitée. Un design à la fois épuré et industriel. La sonorité est légèrement chaude (plus ample et chaude que sur le TA-02) comme on pourrait l’attendre d’un ampli à tubes mais sans excès. Tout le spectre est bien représenté et équilibré. Belles basses, beaux médiums, des aigus fins et détaillés. De toute évidence, sans dureté ou acidité avec une voix de soprano, un violon ou une trompette mais sans douceur excessive non plus.
Pour l’instant, j’ai associé l’ampli xDuoo TA-26S à un lecteur Denon DCD-1700NE afin d’écouter une collection de CD et SACD. Après avoir essayé divers câbles d’alimentation, Isotek, Supra, Silent Wire, j’ai choisi les câbles Isotek, très bien sur le lecteur et l’ampli casque. J’ai essayé aussi divers câbles RCA, Canare, Atlas, Gotham GAC 4/1. Finalement, j’ai installé un Sommercable Epilogue parfaitement équilibré et transparent. Il se marie très bien avec le xDuoo TA-26S.
Avec ce xDuoo certains casques même audiophiles ne sont pas compatibles. L’impédance démarre à 60Ω. Il faut donc se tourner vers les casques à haute impédance.
Sennheiser HD600 / 300Ω / 97dB, excellente sonorité claire, aérée et détaillée. L’ampli xDuoo ainsi qu’un nouveau câble fait sur mesure (Mogami) pour le HD600 ajoutent des basses, une touche de chaleur et plus de douceur aux aigus. Une écoute à la fois analytique et hi-fi. Volume à 9h-10h.
Beyerdynamic DT880 Edition / 600Ω / 96dB, belle sonorité pleine et profonde, bien équilibrée sur l’ensemble du spectre, légèrement chaude, à la fois lisse et détaillée. Avec l’impédance élevée du DT880 on peut monter un peu le volume ce qui permet d’avoir aussi plus de détails sur les instruments en donnant l’impression de s’approcher du centre de la scène sonore. Le xDuoo s’exprime parfaitement avec un casque à 600Ω. Volume à 11h-12h.
AKG K612 PRO / 120Ω / 101dB, très belle sonorité équilibrée, enveloppante, à la fois douce et détaillée sans être trop analytique. Le xDuoo fait bien ressortir les basses du K612. Elles ne sont pas très tendues mais paraissent naturelles. Une sonorité très agréable et reposante pour une écoute hi-fi. Volume à 10h.
FiiO FT3 / 350Ω / 105dB, un son dynamique fin, précis, aéré et détaillé. De l’espace et de la profondeur. Reverb et delay des enregistrements ressortent particulièrement avec l’impression d’être en concert. Le xDuoo et le FT3 s’accordent parfaitement. Volume à 9h-10h.
Audio-Technica ATH-R70x / 470Ω / 98dB, sonorité claire, aérée et dynamique. Des attaques vives et rapides. Basses tendues, définies et un peu en retrait. Une sonorité précise à tendance studio mais très attirante pour une écoute hi-fi. Le xDuoo apporte un peu de chaleur et une touche vivante au réalisme sonore de l’Audio-Technica. Volume à 9h-10h.
On a vraiment envie d’écouter de la musique le plus longtemps possible avec chacun de ces casques pour une multitudes de raisons différentes. Le xDuoo TA-26S met bien en valeur toutes les qualités de ces casques. L’ampli est à l’aise avec les diverses musiques écoutées, rock prog, fusion, jazz, classique symphonique, baroque, sacré… Et surtout, très à l’aise avec de la musique classique contemporaine comportant de l’espace, des longues notes, des harmoniques et de la complexité entre les instruments. Très à l’aise aussi avec les voix du jazz ou les effets spéciaux d’une guitare électrique. Le xDuoo est vraiment capable d’entrer dans les détails de manière parfaitement naturelle.
The magic of electronic tubes
An inexpensive headphone tube amplifier with a great audio quality out of the box.
It improves as the time goes by.
A great amplifier that puts all my high impedance headphones singing with authority.
Probably my best bargain in Hi-fi.
Outstanding.
The TA-26S from xDuoo is a tube headphone amplifier, with a nice design that reveals a smooth, warm and accurate sound. It embarks for that a 6N8P...
