HA INFO NG94 MKII - Headphone amplifier - Preamp - DAC 2xPCM1794
By buying this product you get 25 loyalty points
Reference : 5308
259,00 €tax incl.
215,83 € tax excl.
HA INFO NG94 MKII - DAC Headphone Amplifier - DAC 2xPCM1794
It is the most successful DAC in the HA INFO range, especially in its MKII version
This DAC Headphone Amplifier has several digital inputs:
  • Optical Input
  • BNC Input (RCA Adapter)
  • USB Input (16bit / 44kHz)
The analog signal is output on the front of a 6.35 jack .
This output is variable in volume, it can also be used as a preamp with a jack adapter 6.35 to RCA
Either on the rear panel , on 2 RCA sockets , but at fixed volume.
An integrated amplifier is therefore necessary but the signal does not pass through the variable part and the potentiometer.
The analog part is completely symmetrical and uses the best available components:
  • Yageo SMD Resistors
  • Nichicon and Wima Audio Capacitors
  • Philips High Speed ​​Diodes
  • Burr-Brown Digital Receiver DIR9001
  • Output filter with AD OP275 & BB OPA2134UA
  • Metal Resistors 1%
  • BENNIC XPP Connection Capacitors 5%
  • ALPS Potentiometer
  • Shielded transformer
  • Converter AD 1955
Characteristics :
Dynamic range> 120dB
THD0.0005%
Frequency Response20Hz -> 20kHz
Sampling24Bit-96kHz (SPDIF) - 16Bit-44kHz (USB)
USB InputPC2001 USB Windows / MAC
Line out3V RMS
Headphones9V RMS
Consumption10W
Comes with USB cable, AC cord and BNC / RCA adapter
Module AD1955
InputBNC
OutputJack 6.35mm
Max sampling rate96kHz
