MiniDSP 2x4 HD Interface / IIR Crossover / DAC 24bit 96Khz
4.7 / 5
By buying this product you get 27 loyalty points
Reference : 10813
279,00 €tax incl.
232,50 € tax excl.
Shipping date: 16-06-2026.
MiniDSP 2X4 HD Interface
IIR digital filter / DAC 24bit 96Khz
The MiniDSP 2X4HD interface is a processor for digital filtering. It uses a 24 bit / 192khz DAC (digital / analog converter) with SPDIF Toslink & asynchronous USB Audio Class 2.0 inputs. As most of miniDSP devices, 2x4 HD provides powerful, accessible tools to implement a digital filter (IIR Butterworth / Linkwitz Riley 6 to 48dB) and a parametric equalizer. It will suit audiophiles who want to set an effective correction on a pair of stereo speaker. The device can also be used to manage multiple subwoofers in a home theater setup.
In addition to its digital input, the 2x4 in miniDSP has a stereo analog input on RCA connector for connecting another Hi-Fi device with analog output. Such as a turntable via a RIAA box, or any other analog source. It is a great accessory to centralize the whole installation on a single pair of speakers, while enjoying a correction / filter that extends to the entire chain.
Interface presentation
Plug-in miniDSP 2x4 HD
Processor capacity with FIR and IIR ADSP21489:
The computing power of the Analog Device ADSP21489 processor floating point calculation allows management of finished impulse response FIR type allowing linear curves digital adjustments with high precision. One can thus use the type of conventional technology IIR and FIR according to one's specific need for optimal results.
The MiniDSP 2X4 HD is a Swiss Army knife of digital analog digital filter providing a complete solution with USB / SPDIF input / analog parametric equalizer.
Inside view
This product is also available as a module (bare PCB as presented above) for the purpose of custom integration.
You can upgrade this device into a DDRC-24 by buying a DIRAC LIVE licence at MiniDSP. to find the whole process and buy a licence. Go to this webpage (miniDSP website) if you ever need to upgrade your 2x4HD.
TypeDigital filter
DAC
USB interfaceXMOS X200
ADC / DAC24 bit
ControlRemote control (included)
Windows PC interface (requires Adobe Flash, Adobe AIr & Net Framework)
Digital inputsUSB Input: Windows-compatible ASIO 24bit 192khz asynchronous
digital SPDIF Toslink with asynchronous processor ASRC (20-216Khz)
Analog inputsanalog stereo input RCA phono level of 2V input (or 4V by jumpers)
analog input impedance 10KOhm
0003 THD, 103dB dynamic
Analog outputs4 analog outputs on RCA phono connectors
2Vrms Output Level
Output Impedance 560 Ohm
THD 0.001%
Power supply12V VDC connector 5.5 / 2.1mm (2.5W) - Power supply provided
Dimensions27 x 119 x 107mm
Package Contents
Interface miniDSP 2x4HDx1
12V adapter plug UK / EU / US / AUx1
Shielded USB cablex1
Code to download the plug-in 2 x 4x1
Package1x MiniDSP 2x4 HD
1x 12V power supply
1x Shielded USB cable
1x Remote
Max sampling rate96kHz
11 reviews
Helps integrating multiple subs as one for my home cinema.
This review has been posted for MiniDSP 2x4 HD Interface / IIR Crossover / DAC 24bit 96Khz
très bon filtre actif
Cet appareil fonctionne vraiment très bien, pas de souffle, l'utilisation d'un filtre actif de ce type avec corrections paramétriques fait un petit miracle sur des enceintes 2 voies.
Si bien paramétré, le gain par rapport à un filtre passif est bien réel: meilleure transparence et définition, la scène sonore est plus aérée. Bien que les DAC du minidsp soient plutôt basiques, on se rend compte qu'ils ne sont absolument pas le maillon faible du système audio.
Du coup j'ai fait l'acquisition du minidsp SHD et conserve le 2X4 HD pour un deuxième système. Je ne pense pas revenir au filtrage passif
Excellent
Je l'utilise configuré tel que fourni c.a.d. 2 voies par canal. 1er essai sans rien changer donc partage à 1000 Hz/48dB/oct. sans réserves question distorsion, bruit de fond, transparence, ouverture, on l'oublie, la séparation est d'une efficacité parfaite (j'avais un filtre actif analogique). Ensuite passé à 200 Hz/24dB pour mes large-bande + grave sur baffles ouverts, encore mieux. Réglages faciles, pas de distorsions audibles, pas de clipping, en sortie 2 amplis stéréo pot. entre 25 et 30%. Mesures avec R.E.W. et Umik1 partagé avec un ami, export/import fichier facile aussi, mais c'est là que ça se corse, il faut apprendre à ne pas en abuser. A ce stade mon impression est que la recherche d'une courbe vraiment linéaire est peut-être une fausse piste mais je n'ai pas assez de recul, il faut expérimenter et il y a de quoi faire, surtout si on s'aventure du côté des filtres F.I.R.! . En tous cas je ne regrette pas, c'est un outil sérieux, pratique, efficace. Un petit bémol, je comptais lui dédier un mini pc Asus avec Windows XP et je n'ai pas pu faute de compatibilité du logiciel fourni avec je crois Adobe AIR (nécessaire en version récente refusée par XP), dans les fichiers fournis il y a pourtant un pilote pour XP-Vista ce qui induit en erreur, mais ce n'est pas grave. L'interface de commande/synchronisation est un peu rustique mais fonctionne très bien. Donc je suis très satisfait et aussi très conscient du chemin à faire pour en exploiter les possibilités. Très intéressant !!!
Impressed
I am using the 2x4HD for a 2.2 system, 2 subwoofers and 2 full range DIY speakers. I found the miniDSP quite easy to install and setup, functionality is outstanding and in terms of sound quality it seems transparent (at least enough for me).
MiniDSP 2x4HD
Excellent product and service. Ordered online from UK, Product was delivered within three days and it was cheaper than purchasing it from within the UK (even with special TNT delivery). I would definitely buy from this company again. Great service.
