Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Richard H.
Dayton Audio BST-300EX
précis et chaleureux
Eric v.
bonne prise
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 19902
    In Stock
    Jantzen Audio Ceramic are affordable, stable ceramic resistors, ideal for loudspeaker design. They tolerate high temperatures and are particularly shock-resistant. Ceramic resistors offer excellent performance at an affordable price.
    0,40 € 0,33 €Ex.
    In Stock
  • Ref : 18718
    In Stock
    Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact and giving them better sonic properties than standard film capacitors. With a nominal voltage of 160V DC, these capacitors are also more versatile than electrolytic capacitors.
    1,00 € 0,83 €Ex.
    In Stock
  • Ref : 18719
    In Stock
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 18720
    In Stock
    1,50 € 1,25 €Ex.
    In Stock
  • Ref : 18721
    1,60 € 1,33 €Ex.
    In Stock
  • Ref : 18722
    In Stock
    1,70 € 1,42 €Ex.
    In Stock
  • Ref : 18723
    In Stock
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 18724
    In Stock
    2,20 € 1,83 €Ex.
    In Stock
  • Ref : 18725
    In Stock
    2,40 € 2,00 €Ex.
    In Stock
  • Ref : 18726
    In Stock
    2,70 € 2,25 €Ex.
    In Stock
  • Ref : 18727
    In Stock
    3,20 € 2,67 €Ex.
    In Stock
  • Ref : 18728
    In Stock
    3,60 € 3,00 €Ex.
    In Stock
  • Ref : 18729
    In Stock
    4,60 € 3,83 €Ex.
    In Stock
  • Ref : 18730
    In Stock
    5,30 € 4,42 €Ex.
    In Stock
  • Ref : 18731
    In Stock
    6,40 € 5,33 €Ex.
    In Stock
  • Ref : 18732
    In Stock
    8,60 € 7,17 €Ex.
    In Stock
  • Ref : 18733
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 18734
    In Stock
    17,10 € 14,25 €Ex.
    In Stock
  • Ref : 18735
    In Stock
    20,90 € 17,42 €Ex.
    In Stock
  • Ref : 18736
    In Stock
    25,70 € 21,42 €Ex.
    In Stock
  • Ref : 18737
    In Stock
    28,90 € 24,08 €Ex.
    In Stock
  • Ref : 18738
    In Stock
    35,40 € 29,50 €Ex.
    In Stock
  • Ref : 21002
    Jantzen Audio Cross Coil have been developed in cooperation with Audio Technology (Denmark). They offer reduced distortion and greater dynamic range than conventional coils. This flat-film copper coil has a cross-section of 12AWG, an inductance of 0.15mH and a DC resistance of 0.07Ω.
    36,90 € 30,75 €Ex.
    In Stock
  • Ref : 11623
    In Stock
    Jantzen Cross Coils are the closest thing to a perfect inductor available today. They have been developed together with Audio Technology (Denmark) for the filtering of their product. Each coil is individually tested with the Clio measuring system.
    110,00 € 91,67 €Ex.
    In Stock
  • Ref : 11622
    In Stock
    142,20 € 118,50 €Ex.
    In Stock
  • Ref : 11626
    20,20 € 16,83 €Ex.
    In Stock
  • Ref : 18887
    In Stock
    Jantzen Cross Coils are currently the closest thing to a perfect inductor. They have been developed in conjunction with Audio Technology (Denmark) for the filtering of their product. Each coil is individually tested with the Clio measurement system.
    24,10 € 20,08 €Ex.
    In Stock
  • Ref : 18889
    In Stock
    27,50 € 22,92 €Ex.
    In Stock
  • Ref : 6572
    In Stock
    27,80 € 23,17 €Ex.
    In Stock
  • Ref : 19709
    43,40 € 36,17 €Ex.
    In Stock
  • Ref : 11624
    77,30 € 64,42 €Ex.
    In Stock
  • Ref : 11625
    132,00 € 110,00 €Ex.
    In Stock
  • Ref : 18884
    In Stock
    18,60 € 15,50 €Ex.
    In Stock
  • Ref : 16007
    25,40 € 21,17 €Ex.
    In Stock
  • Ref : 16006
    28,60 € 23,83 €Ex.
    In Stock
  • Ref : 19710
    Jantzen Audio Cross Coil have been developed in cooperation with Audio Technology (Denmark). They offer reduced distortion and greater dynamic range than conventional coils. This flat-film copper coil has a cross-section of 16 AWG, an inductance of 0.68 mH and a DC resistance of 0.29Ω.
    31,50 € 26,25 €Ex.
    In Stock
  • Ref : 12359
    45,90 € 38,25 €Ex.
    In Stock
  • Ref : 19980
    In Stock
    Jantzen Audio Cross Cap capacitors offer a high level of performance and quality at a very reasonable price. This is a versatile model, using metallized polypropylene foil.
    1,10 € 0,92 €Ex.
    In Stock
  • Ref : 19995
    1,10 € 0,92 €Ex.
    In Stock
  • Ref : 19996
    In Stock
    1,40 € 1,17 €Ex.
    In Stock
