Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Color
Electronic components
Jean-louis L.
Jean Michel P.
Hervé R.
Pas si bien que ça !
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 20014
    In Stock
    Jantzen Audio Cross Cap capacitors offer a high level of performance and quality at a very reasonable price. This is a versatile model, using metallized polypropylene foil.
    1,84 € 1,53 €Ex.
    In Stock
  • Ref : 20015
    In Stock
    2,39 € 1,99 €Ex.
    In Stock
  • Ref : 20016
    2,44 € 2,03 €Ex.
    In Stock
  • Ref : 20017
    2,44 € 2,03 €Ex.
    In Stock
  • Ref : 20018
    2,59 € 2,16 €Ex.
    In Stock
  • Ref : 20019
    3,29 € 2,74 €Ex.
    In Stock
  • Ref : 20020
    3,49 € 2,91 €Ex.
    In Stock
  • Ref : 20021
    3,99 € 3,33 €Ex.
    In Stock
  • Ref : 20022
    In Stock
    4,49 € 3,74 €Ex.
    In Stock
  • Ref : 20023
    5,19 € 4,33 €Ex.
    In Stock
  • Ref : 20024
    In Stock
    6,84 € 5,70 €Ex.
    In Stock
  • Ref : 20025
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 20026
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 20027
    16,99 € 14,16 €Ex.
    In Stock
  • Ref : 20028
    65,99 € 54,99 €Ex.
    In Stock
  • Ref : 20029
    77,69 € 64,74 €Ex.
    In Stock
  • Ref : 20030
    92,79 € 77,33 €Ex.
    In Stock
  • Ref : 11761
    In Stock
    Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers.  Made in Europe, this new competitor of the German, French and English references enjoys a very good design quality. They are ideal for parallel RL and RLC "plug" correction in parallel circuit, instead of low quality...
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 11762
    In Stock
    2,10 € 1,75 €Ex.
    In Stock
  • Ref : 11781
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 11770
    In Stock
    5,50 € 4,58 €Ex.
    In Stock
  • Ref : 14380
    In Stock
    42,90 € 35,75 €Ex.
    In Stock
  • Ref : 15614
    In Stock
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 15166
    In Stock
    47,90 € 39,92 €Ex.
    In Stock
  • Ref : 11771
    In Stock
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 11772
    In Stock
    7,50 € 6,25 €Ex.
    In Stock
  • Ref : 11760
    In Stock
    1,20 € 1,00 €Ex.
    In Stock
  • Ref : 11763
    In Stock
    2,40 € 2,00 €Ex.
    In Stock
  • Ref : 18021
    2,60 € 2,17 €Ex.
    In Stock
  • Ref : 18022
    In Stock
    2,80 € 2,33 €Ex.
    In Stock
  • Ref : 13740
    In Stock
    Jantzen Audio Cross Cap MKP 400V capacitors are considered to be the best value for money for the design of passive filters for loudspeakers. Of European manufacture, this new competitor to the German, French and English references enjoys a very high quality of design.
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 11773
    In Stock
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 11764
    In Stock
    3,20 € 2,67 €Ex.
    In Stock
  • Ref : 11765
    In Stock
    3,50 € 2,92 €Ex.
    In Stock
  • Ref : 11774
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 11775
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 15563
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 11776
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 11766
    In Stock
    4,50 € 3,75 €Ex.
    In Stock
  • Ref : 11777
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
