Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
YANN P.
Excellente barette secteur
Jeroen v.
Jeroen
Kah Yeow K.
Great cable for REL
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 2409
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. This makes it possible to achieve better inductances while maintaining low internal impedance and zero...
    179,00 € 149,17 €Ex.
    In Stock
  • Ref : 2411
    In Stock
    289,00 € 240,83 €Ex.
    In Stock
  • Ref : 5096
    In Stock
    55,90 € 46,58 €Ex.
    In Stock
  • Ref : 5094
    In Stock
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 5098
    In Stock
    65,90 € 54,92 €Ex.
    In Stock
  • Ref : 5099
    In Stock
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 5102
    In Stock
    85,00 € 70,83 €Ex.
    In Stock
  • Ref : 5103
    In Stock
    92,90 € 77,42 €Ex.
    In Stock
  • Ref : 5105
    In Stock
    129,00 € 107,50 €Ex.
    In Stock
  • Ref : 5106
    In Stock
    95,00 € 79,17 €Ex.
    In Stock
  • Ref : 5114
    In Stock
    309,00 € 257,50 €Ex.
    In Stock
  • Ref : 5116
    In Stock
    195,20 € 162,67 €Ex.
    In Stock
  • Ref : 2829
    In Stock
    Using a set of 7 wires twisted then varnished, this type of coil has a larger wire surface compared to a single-stranded conductor. This technique gives a better conductivity in the high frequencies (skin effect) and a reduced noise (varnish).
    15,70 € 13,08 €Ex.
    In Stock
  • Ref : 2830
    In Stock
    16,60 € 13,83 €Ex.
    In Stock
  • Ref : 2831
    In Stock
    17,50 € 14,58 €Ex.
    In Stock
  • Ref : 2826
    In Stock
    14,70 € 12,25 €Ex.
    In Stock
  • Ref : 2832
    In Stock
    19,40 € 16,17 €Ex.
    In Stock
  • Ref : 2833
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 2834
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 2835
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 2836
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 2837
    In Stock
    52,90 € 44,08 €Ex.
    In Stock
  • Ref : 2838
    In Stock
    43,90 € 36,58 €Ex.
    In Stock
  • Ref : 2839
    In Stock
    32,40 € 27,00 €Ex.
    In Stock
  • Ref : 2841
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 2842
    40,80 € 34,00 €Ex.
    In Stock
  • Ref : 2843
    99,90 € 83,25 €Ex.
    In Stock
  • Ref : 2840
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 2844
    In Stock
    51,90 € 43,25 €Ex.
    In Stock
  • Ref : 2845
    69,90 € 58,25 €Ex.
    In Stock
  • 6,90 € 5,75 €Ex.
    In Stock
  • 49,90 € 41,58 €Ex.
    In Stock
  • 9,90 € 8,25 €Ex.
    In Stock
  • 11,90 € 9,92 €Ex.
    In Stock
  • 6,90 € 5,75 €Ex.
    In Stock
  • 6,50 € 5,42 €Ex.
    In Stock
  • 6,90 € 5,75 €Ex.
    In Stock
  • 14,90 € 12,42 €Ex.
    In Stock
  • 7,90 € 6,58 €Ex.
    In Stock
  • 7,90 € 6,58 €Ex.
    In Stock
