Impedance (Ω)
Speaker Type
Diaphragm type
Loudspeaker diameter (mm)
9 - 203
Efficiency / Sensitivity (dB)
85 - 102
Xmax (mm)
1 - 4
Lowest frequency (Hz)
10 - 310
Highest frequency (Hz)
0 - 56000
Speaker Power (W RMS)
0 W - 305 W
Marcus L.
Michael M.
Worth every penny!
mathieu l.
Exciters
This section presents all our exciters, allowing the creation of a sound wave by the vibration of a surface. Many brands are represented, allowing everyone to find a model that will suit his project. The filters on the page allow you to make a more precise selection according to your needs.
