Connector
Max cable diameter (mm)
Rated current (A)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
Roland S.
Dac tv
Walter V.
Great product!
Joli mais non..
IEC Connectors
Discover our range of IEC connectors of all sizes, for the design of your HiFi power cables.
