1MII RT5066 WiFi Audio Transmitter Receiver
New
The 1Mii RT5066R1 is a kit comprising a WiFi audio transmitter and receiver, designed to transmit the signal from a source to an audio system without a wired connection between the two devices. Its RCA connectors allow you to connect a TV, a CD player or a computer to a powered speaker, an active subwoofer or an amplifier equipped with a suitable input. The kit transmits only the audio signal: it does not replace an amplifier and therefore cannot directly power a passive speaker.
Reference : 22562
52,90 €tax incl.
44,08 € tax excl.
1Mii RT5066 WiFi Audio Transmitter Receiver 2.4GHz
1MII RT5066: Front view
The 1Mii RT5066R1 is a kit comprising a WiFi transmitter and receiver, designed to transmit the signal from a source to an audio system without a wired connection between the two devices. Its RCA connectors allow you to connect a TV, a CD player or a computer to a powered speaker, an active subwoofer or an amplifier equipped with a suitable input. The kit transmits only the audio signal: it does not replace an amplifier and therefore cannot directly power a passive speaker.
Operating on the 2.4GHz band, the RT5066R1 claims a range of up to 100m outdoors and 30 to 50m indoors, depending on obstacles and surrounding interference. The manufacturer indicates a latency of less than 20ms, in order to maintain good synchronization between image and sound when used with a TV. Once the two units are connected and powered, they pair automatically, which makes it easy to set up a powered speaker or subwoofer located far from the source.
Technical specifications
Product typeWiFi receiver / transmitter
Inputs1x stereo RCA
Outputs1x stereo RCA
Transmission range100m with no obstacle
Frequency band2.4 GHz
Supply voltage5V DC
Package1x 1Mii RT5066R1 Transmitter
1x 1Mii RT5066R1 Receiver
2x RCA to 3.5mm Jack cable
2x USB-A to DC Jack power cable
DAC / ADC ChipNC
Transmission / Reception protocolWiFi
Supported Bluetooth codecsN/A
1MII RT5066 WiFi Audio Transmitter Receiver 2.4GHz
The 1Mii RT5066R1 is a kit comprising a WiFi audio transmitter and receiver, designed to transmit the signal from a source to an audio system...
