This product has been replaced by the new version, the AUNE X5S 8TH ANNIVERSARY.
High Definition Digital Music Player 32bit 384kHz DSD256 CPLD Silver
For its 6th anniversary edition, Aune unveils an updated version of the X5S with an optimized circuit. This 100% digital audio file player supports almost all formats including DSD up to DSD256. It can read WAV, FLAC, APE and DSD formats.
The ARM + CPLD + DSD1793 architecture offers comfortable computing power for digital transport of this gauge. The X5S 6th Anniversary thus offers a very clean signal, with 133.8 dB THD+N @ 1kHz, 0dB and an extremely low jitter of 2.7NS.
It has a large OLED screen providing all the essential information to check that the reading takes place in the best conditions and that all the parameters are respected (frequency, bitrate...etc). The X5S 6th anniversary player can be controlled with an I/R remote control (supplied with the exception of the island).
Equipped with a diversified connectivity (AES/EBU - Optical Toslink - RCA Coaxial), it is able to drive a very wide range of audio DACs. In addition, the front of the unit features an SD card reader from which the X5S will be able to read audio files.
If the X5s 6th Anniversary is used with an X1S (same manufacturer), the set benefits from a SPDIF capacity exceeding the standard 192kHz ceiling. Such a coaxial / SPDIF line can run DSD128 - 32bit/384KHz streams autonomously.
| Specifications | |
| Product type | Digital music player |
| Clocks | Crystek |
| Display | OLED |
| Remote control | Yes (battery not included) |
| RCA output level | 2Vrms |
| RCA output frequency response (+/-0.5dB) | 20Hz - 20kHz |
| RCA output noise | 5.4µV |
| RCA output THD+N | -101dB |
| Supported file formats | WAV : Up to 32bit 384kHz, WAV + CUE FLAC : Up to 32bit 384kHz, 0-8 level DSD : DSF / DFF up to DSD256, SACD-ISO APE : 16bit 44.1kHz ALAX AAC MP3 |
| THD+N | -98.25dB @ 16bit 44.1kHz, 1kHz 0dB -137.8dB @ 24bit 96kHz, 1kHz 0dB -141dB @ 24bit 192kHz, 1kHz 0dB |
| Jitter | 237.6ps |
| Inputs | 1x SD Card (Max 128Go, exFAT) 1x USB-A (Max 2Tb, exFAT) |
| Outputs | 1x Coaxial 1x Optical 1x AES 1x RCA |
| Package | 1x Aune X5s 6th Silver 1x Power supply 1x Remote control |
| Dimensions | 171 x 145 x 45mm |
| Input | SD Card |
| Output | Coaxial SPDIF |
| Output | Optical Toslink |
| Output | XLR |
| Output | RCA |
| Max sampling rate | 384kHz |
| Max sampling rate | DSD256 |
| Color | Silver |
